Outside temperature off
I just went searching for the Ambient Air Temp. Sensor and found the reason for the open circuit, and why my a/c isn't working.... The wiring has been cut, and the sensor is missing all together. I have called every junkyard I can find, and have tried LKQ and all the parts stores. Does anyone know where I can find the pigtail for an 08-13 Infiniti G37 Ambient Air Temp. Sensor??? Thanks in advance for the help!
Just had to replace the sensor (and the pigtail, as the previous owner CUT IT, and next to impossible to find a used wiring harness, and subsequently the pigtail). I digress, yes there is an aluminum bar that sits just in front of the radiator. It is a funky looking sensor, as there is a lot of plastic that makes it able to snap into the little prong that juts out from the bar. My inside temp was not reading, and the AC would not work. Just by replacing the sensor, the AC is now cold as hell! 2 months to find pigtail 10 minutes to fix
how much is just the sensor?
Are you talking about this thing? This sensor effects whether the AC blasts cold or not?? I thought it just read temperature
redlinernyc
02-29-2016 11:06 PM
