vdc and slip light is on
hey,
i've noticed this promblem since last week, when ever i push the car over 5-6 rpms my vdc and slip light goes on and stays on till i turn the car off and then it goes away when i start it back up, and i notice that my brake light comes on too but doesnt stay on like the vdc and slip light.
CrystalTheG (06-19-2018)
According to the manual, if the VDC OFF and SLIP lights illuminate constantly while the car is running, there may be problem with the VDC system and it is operating in "fail-safe mode." The car will still be drivable but you should take it to the dealer ASAP.
Zelf24 (01-07-2016)
i actually recently had that problem as well. the first time i took the car in because of the lights, they diagnosed it as my ABS actuator that had went out on me. However, that had happened a second time.. the second time they just needed to adjust something on the brake pedal. Hopefully your situation just calls for adjusting of the brake pedal.
Zelf24 (01-07-2016)
Umm it makes sense guys. When you accelerate hard the fluid in the master cylinder moves towards the back and obviously sets off the level light. If the brake fluid level is low then abs and vdc (which uses brakes) will fault too. I just had this occur tonight and was freaked out! I'm going to check levels and let you guys know the results.
It can be the pads too, as others mentioned, doesn't have to be the fluid. I tried adding fluid since I still had ~15% of pads left on my 07 G35X @ 75k. Didn't help. So I replaced the pads and rotors and the light hasn't come back in 10k and over a year.
