Best Springs for fronts only?
Hi, looking to drop the front a bit on the g37s vert. Anyone know the best front springs to go with without having to buy camber kits? Did some research and swift or eibach seem to be the top 2 and just keeping the rears stock.
if you have pics of this setup please post, thanks!
The vert is a tough one regarding suspension since it's weight is beastly vs. anything else in the Infiniti & Nissan lineup, closest curb weight would be the GTR.
Black Betty gives good advice, might look into a coilover set that will drop the least amount, but keep in mind many sets drop quite a bit even at their highest settings, so it will take a bit of research.
G/L
G/L
I have 2013 Ipl vert and am considering mild front only drop and keep rear stock. Anyone try Tanabe nf210 in front only? Seems like a lot of the coupe guys that only want a mild front drop are doing that. I think the rear wheel gap of the ipl vert is ok with some spacers.
19s with NO CAMBER KITs.
Front - Eibach pro-kit springs
Rear - G37S COUPE OEM springs
I think it sits evenly with front and rear. I think it gave me about an inch drops on both. Maybe a bit more. I like it .
