Akebono BBK for vert
Old 01-16-2014, 12:14 PM
weird60625
weird60625's Avatar
i wanna to upgrade to Akebono BBK for my 09 vert , did anyone do this upgrade and what i need to do before order the akebono kit ? Thanks
Old 08-30-2014, 01:55 PM
Redfire32
Ginger ninja
Redfire32's Avatar
I did it with my 12 vert. My advice is go to the classifieds n save some chedder. Some great advice I got for blnewt was if I bought good used mods I could usually get 70-80% of the $ back when I decided to sell or upgrade. Perhaps you should consider the same bro.
Old 09-05-2014, 04:29 PM
NBE-ON'D
NBE-ON'D's Avatar
If you can find someone selling a factory sport set, that would work nicely.
Calipers/mounting brackets and like redfire said save money. They bolt up, you don't have to change (master cylinder), or worry about how much power (vac-break booster) to power them to get the stopping benefits. Plus they are a good set engineered for the cars supporting components. Rotors likely for you application are not too pricy (single piece slotted, stay away from drilled iron rotors, they only look sporty lol) so start new and bed them in with a quality set of pads. Also because you'll need to bleed it all, maybe think of putting on steel lines and you'll have much better feel but its not necessary.
Im sure the verts weigh more so you'll really like how this upgrade turns out for you. Kudos, that's a smart upgrade, and the akebono calipers have fantastic power, initial bite and surface distribution/contact with the pads and rotors.
O make sure your wheels will have the clearance with the bigger calipers.
Best of luck and let us know how she turns out.
Cheers
ck1109
10-15-2015 11:06 PM
Kojack
10-09-2015 05:53 PM
faze2988
10-07-2015 12:05 AM
VIVID
09-27-2015 09:45 AM
Allboutcali
09-26-2015 03:43 PM
Quick Reply: Akebono BBK for vert
