Factory Service Manual (FSM) for convertible
Old 11-19-2010, 02:25 AM
Fezzik
Fezzik's Avatar
Exclamation Factory Service Manual (FSM) for convertible
Thought I'd share this to the community I paid a membership and got updated NICOs FSM for the G37 and 370z. May want to sticky this.
Factory Service Manual in PDF format.
Index of /FSM/G37
Fezzik is offline
The following 8 users liked this post by Fezzik:
2mnycars (09-01-2016), Autocutter (04-14-2016), Coy1231 (11-10-2014), ddny (06-28-2019), DGL (06-23-2013), Glnipl (09-05-2023), GoodGalz (05-12-2017), rdog (09-19-2016) and 3 others liked this post. (Show less...)
Old 11-19-2010, 02:29 AM
Luke B.E
Luke B.E's Avatar
nice~~~~~~~~~~~~~
Luke B.E is offline
Old 05-28-2016, 01:25 PM
afar1
afar1's Avatar
In the menu, open "GI", general information, see page 5 in the symbols table for the symbols explanations and the torque units. The numbers in the parentheses are torque specs in metric and non-metric units.
Also, pay attention to the color of the torque symbol, white for ft-lb, black for inch-lb; it's all there.
http://www.nicoclub.com/FSM/G37/Coupe/2013/GI.pdf
afar1 is offline
Old 09-06-2016, 02:26 AM
Melophile
Melophile's Avatar
All this can be found in the FWD chapter of the factory service manual, but I wanted to write this up for people, like me, who didn't know about the FWD chapter.
I would've hyperlinked everything below, but I didn't want to mix up different years/models so I figured writing out the chapter abbreviations would suffice. I also would've posted this in the Coupe section, but the factory service manual thread over there is locked.
General Information
  • GI - General Information
Engine
  • ACC - Accelerator Control System
  • CO - Engine Cooling System
  • EC - Engine Control System
  • EM - Engine Mechanical
  • EXT - Exterior
  • FL - Fuel System
  • LU - Engine Lubrication System
  • STR - Starting System
Transmission & Driveline
  • CL - Clutch
  • DLN - Driveline
  • FAX - Front Axle
  • RAX - Rear Axle
  • TM - Transaxle & Transmission
Suspension
  • FSU - Front Suspension
  • RSU - Rear Suspension
  • WT - Road Wheels & Tires
Brakes
  • BR - Brake System
  • BRC - Brake Control System
  • PB - Parking Brake System
Steering
  • ST - Steering System
  • STC - Steering Control System
Restraints
  • SB - Seat Belt
  • SBC - Seat Belt Control System
  • SR - SRS Airbag
  • SRC - SRS Airbag Control System
Ventilation, Heater & Air Conditioner
  • HA - Heater & Air Conditioning System
  • HAC - Heater & Air Conditioning Control System
  • VTL - Ventilation System
Body Interior
  • ADP - Automatic Drive Positioner
  • INT - Interior
  • IP - Instrument Panel
  • SE - Seat
Body Exterior, Doors, Roof & Vehicle Security
  • BRM - Body Repair
  • DLK - Door & Lock
  • EXT - Exterior
  • GW - Glass & Window System
  • PWC - Power Window Control System
  • RF - Roof
  • SEC - Security Control System
Driver Controls
  • DEF - Defogger
  • EXL - Exterior Lighting System
  • HRN - Horn
  • INL - Interior Lighting System
  • MIR - Mirrors
  • WW - Wiper & Washer
Electrical & Power Control
  • BCS - Body Control System
  • CHG - Charging System
  • LAN - LAN System
  • PCS - Power Control System
  • PG - Power Supply, Ground, & Circuit Elements
  • PWO - Power Outlet
Driver Information & Multimedia
  • AV - Audio, Visual & Navigation System
  • MWI - Meter, Warning Lamp & Indicator
  • SN - Sonar System
  • WCS - Warning Chime System
Cruise Control & Driver Assistance
  • CCS - Cruise Control System
Maintenance
  • MA - Maintenance
Melophile is offline
The following 2 users liked this post by Melophile:
2mnycars (09-15-2016), GoodGalz (05-12-2017)
Diode Dynamics
Lighting/Cleaning Products
81
11-30-2021 02:28 PM
4DRZ
10-02-2015 09:54 AM
Wreckreation
09-21-2015 06:27 PM
OldG37
09-06-2015 10:38 PM
Quick Reply: Factory Service Manual (FSM) for convertible
