Coolant Leak - Where's this location?
if you are replacing the heater bypass hose it would mean losing quite a significant amount of coolant especially coming out of the heater core. you would definetely need to bleed it if you don't want excess air in the cooling sys causing idling issues or the noise of coolant sloshing around coming from your dash as you make left and right turns.
Nissan 370Z: Eliminating hot coolant heater hoses on both throttle bodies - Nissan 370Z Forum
I wouldn't bother bleeding the system. I have disconnected water hoses from multiple locations, without bleeding the system afterward. Never had an issue, YMMV.
Also I don't know what year is your car, but most likely the hose is not the problem. It's the clamp that's losing tension. So all you really need is to put new clamps on.
I'm thinking if coolant comes out then bleeding is needed but if not then no bleed.
I'm gonna just change the whole hose. Website has it for bout $8 so hopefully dealership is bout same.
Keep the input coming. Appreciate all
Upon further inspection.. It looks like it's leaking from back of engine too . Looks like it is the hose going to the left throttle (passenger). This one might b a little tougher to get to.
Now to back of engine. Is the hose leaking or are those residue from the throttle body leak hose. I zoomed in & doesn't looked to be leaking. Prob need to wiped clean & monitor. Pic 5, is that the plastic coupler?
which sand paper is recomended for cleaning the pipe.. there is some rust/corrosion from the leak coolant. i tried a razor blade but it is not cleaned all the way & afraid it may leak and/or seep. thanks in advance.
pic5 is not a coupler. that is just a holder that keeps the hose in its place. as far as sandpaper i would suggest using steel wool and spraying it with some good lubricant and use that to clean off the rust. then put a little dielectric grease inside the hose so when you slip it on to the throttle body coolant pipe it will not only help the hose slip on easier but prevent corrosion from building up again.
tite_tite (01-15-2017)
Dang it.. It's leaking from back not as bad as the leaked hose replaced. Maybe the clamp cuz it's is only leaking from back but not front. Will most likely change hose & clamp. Hope all goes well.
NOTE: not much coolant came out when leaked hose was replaced so didn't bleed. Will see how I feel after hose replace (back) before bleeding.. Lol
Was searching through threads so hopefully you guys can help me out..about a month back i noticed a leak,it was the tope hose and the oem clamp was fried so i replaced it and filled my coolant tank..last week i noticed the smell coming back and was able to take pictures..if you guys can help me out id appreciate it
i highly recommend you use/get this tool for removing/installing clamp for hose. that little guy will do good!!
Additional pics. Hope this will help the next person. Will update further if leak continue to leak... finger crossed & hope not
pic 1 - hose & part number(s)
pic 2 - the little sucka in the back
pic 3 - ideal position for flashlight. light can be had for FREE at harbor freight. rubber band is VERY important cuz it fell a couple of times + it was stuck on the frame/wire/something..
#29
Help Needed. Can you tell me if this is push in all the way or i need to push the hose further in? it's the hose from the back to the throttle (passenger side). Thanks in advance.
#30
