OBD Scanner/Dongle Q&A Thread
Old 01-02-2017, 01:27 PM
  #31
SonicVQ
SonicVQ's Avatar
Originally Posted by Ape Factory
Anyone having luck recording oil temps using a BT dongle and associated program? OBD Fusion is not registering anything when I select the oil temp PID. Using Apple iOS
OBD Fusion (iOS and Android) do not support extended PIDs, so we can't get oil temp and other data. I emailed the developer and he had concerns about some ECUs doing weird/dangerous things when extended PIDs are enabled.
Torque Pro (yes, Android only) with the Nissan/Infiniti EX plug in are the best options.
Old 01-02-2017, 01:40 PM
  #32
SonicVQ
SonicVQ's Avatar
Originally Posted by Presto
Does anyone know if the newer elm327 v2.1 will be faster sample rates? They are dirt cheap (around $4) so il try one out as well.
ELM327 2.1 will not give faster sample rates, it has added new commands for the CAN bus. The connection protocol/ecu response rate determines how fast we can data log via OBD2.
I have 5 different OBD dongles and the data logging sample rate (PIDs/second) varies from an average of 5 to 35 per second. Buying cheap OBD dongles from Amazon & ebay is a gamble. The fist purchase I got lucky at an average of 24 PIDs/second.
Presto (01-03-2017)
Old 01-04-2017, 03:48 AM
  #33
Presto
Presto's Avatar
this is my el cheapo adapter. BT v 1.5. it does not allow the faster ecu read speed. Have purchased another newer cheap one. lets see if that is any better.
Old 01-14-2017, 02:35 PM
  #34
Lt8Che
'Cuz Racemod-erator
Lt8Che's Avatar
Interested in this thread for sure. I plan on getting the ECU Connect with EcuTek when I get retuned. It seems like it will be very valuable for track days instead of lugging a laptop around and worrying about how to secure it when tossing the G around corners.
Old 01-14-2017, 04:24 PM
  #35
Selym
Selym's Avatar
I have a BlueDriver dongle and their IOS app. I bought it to investigate and clear the recurring P0420 that my '02 Subaru would throw. Will the BlueDriver dongle work with Torque? I have a Nexus 7 that I can run Torque on.
Old 09-10-2019, 06:22 AM
  #36
jben
jben's Avatar
Hello is it possible to erase this "Pop Up Hood" error with Torque Pro and its plugin "Advanced EX for Infiniti" ? this error comes each time the front bumper is removed (for paint).
Thanks for any help
jben
Old 09-10-2019, 11:14 AM
  #37
BeeW
BeeW's Avatar
Thanks for any help
jben
AFAIK, Torque only sends a clear codes command. So unless you're throwing a code, I doubt it will work.
There probably isnt a fuse for that lught specifically you could pull. Alternatively you could find the hood open sensor and trick it, its probably similar to a fridge door light switch.
