Part #s and DIY link for timing gasket failure
Old 10-02-2016, 03:23 PM
Received 4,941 Likes on 4,174 Posts
Here you go and if anyone has actually done this job, feel free to add any helpful tips or anything that needs to be updated/corrected. Thanks! ***********This is the minimum parts req'd, and timing chain/tensioners could also be needed depending on mileage, condition.~
SEAL O RING (20.8MM) - 15066-ZL80C
SEAL O RING (27.7MM) - 15066-ZL80D
SEAL-OIL, CRANKSHAFT - 13510-31U10
GASKET SOLENOID-23797-EY01A
GASKET SOLENOID-23797-JA10B
THREEBOND 1217F GASK-999MP-1217FPP
LONG LIFE ANTIFREEZE-999MP-AF000P
GASKET OIL GALLERY-13533-JK21A
GASKET-FRONT COVER,L-13533-JK21B
And the download link for the DIY to tackle this mess~
http://g35driver.com/forums/attachme...ry-gaskets.pdf
The following 5 users liked this post by blnewt:
Black Betty (10-02-2016), Presto (10-03-2016), skipmycar (03-20-2024), stealthee (10-02-2016), Sunny G (10-02-2016)
Old 05-05-2017, 06:06 PM
jnick
jnick's Avatar
Invoice for Gasket Repair
Thought I'd post this FYI.
My car went into limp mode and displayed a CEL without warning. I drove it to the dealership and got a diagnosis and an estimate in the $3200 - $3900 range. I did some research and contacted a friend who owns a local shop and he was game for the repair.
Here is a picture that he took of the damaged gasket:
The following 2 users liked this post by jnick:
blnewt (06-08-2017), Coltrane1 (11-18-2017)
Old 06-08-2017, 08:23 AM
Ape Factory
Ape Factory's Avatar
Reading about how a 370Z blew the motor in spectacular fashion and the culprit was the oil galley gasket under the FRONT timing cover, not the rear. I've asked for clarification as it seems it's the same part. But if not...both could be potentially weak points, FYI.
Help please, I blew my motor and need to plan the rebuild - Page 5 - Nissan 370Z Forum
EPS Tuning makes a replacement gasket set which I'm sure is designed to be more durable than OEM/OEM redesign but it says rear. So the OP on the 370z forum may have it backwards.
blnewt (06-08-2017)
Old 06-08-2017, 09:49 PM
saywat?
saywat?'s Avatar
so is there a better gasket than oem besides wat ape just mentioned? wats the options?
Old 06-08-2017, 11:33 PM
Selym
Selym's Avatar
Small world! John was my mechanic when I lived in the Capital District. Glad to see he's still doing great work.
Old 11-14-2017, 12:25 PM
Here's a couple videos on youtube of a DIY job, if this ever happens to mine, at least my harmonic balancer bolt isn't subjected to the devil of the rust belt
https://www.youtube.com/watch?v=P1Un...ature=youtu.be
Old 03-11-2019, 01:55 PM
TRENDZ
TRENDZ's Avatar
Mine just failed after a pretty extreme cold snap. Car is a 2008 and has 110,000 miles. Bought it used one year ago. Symptoms were check engine light and limp mode . Code for cam timing. Pulled the oil pan and found gasket parts. Decided to dive in head first. Got it torn down to the galley gaskets, and found a portion of the upper “t” shaped gasket missing. The portion missing was on the upper driver side of the engine. The screw on that very far end of the gasket and the one next to it were much looser then the rest of them. The bottom of the “t” gasket screw took little effort also. That part of the gasket was still intact, but discolored as if had been getting oil soaked from the loose screw.
I ended up also removing the entire rear chain case. The case was leaking oil from the case/ head area. The rear case is mostly a liquid sealant connection other than one O ring for coolant, and one O ring for the main oil pressure feed.
Old 04-13-2019, 05:34 AM
max0ut132
max0ut132's Avatar
Former Infiniti certified technician here.
I believe there is actually an updated OEM rear timing cover to address this issue which ironically is SOMETIMES less expensive than the oil galley gun shaped gaskets and o-rings alone. It comes preinstalled with new oil galley cover plates and gaskets. This also saves some time not having to clean up the old cover and plate surface areas. I believe the cover was updated in 2011 year G's.
Old part #'s: 13500-EY01B, 13500-EY00B
Updated #: 13500-EY03B
13035*A - Rear timing cover assembly
Also not sure if this is mentioned but it is usually advised to replace both intake phasers or at the very least whichever one throws the INT cam code for being out of time. The phasers are very susceptible to damage when they are not getting enough oil due to the inherent loss of pressure with this issue.
As always, be sure to inspect the chain, guides, and oil jets for any damage that may have incurred from the chain having too much slack.
Good luck to all. Keep our G's on the road!
Max
Last edited by max0ut132; 04-13-2019 at 05:37 AM. Reason: Incorrect year for updated part inclusion
Baadnewsburr (04-13-2019)
looksezontv
06-05-2019 05:13 PM
Loki05
11-23-2016 12:59 PM
VIVID
10-14-2016 12:01 PM
Quick Reply: Part #s and DIY link for timing gasket failure
