First Stillen SC A-A Upgrade Kit - G37xs
#31
Yeah I just saw that too...
Update: Sebastian thinks I have an issue with my fuel return still, so I'm going to have to find a way to monitor my gauge in the bay, while driving in WOT. I'm thinking ghetto duct tape an led in there with a gopro?
#33
Yeah I'll figure something out. I don't see us getting very far into the tuning for a couple weeks at this point. Charles told me that he just finished the design on the new S1 kit, so I may just do that, while my shop goes over the fuel return system again.
#34
It features a custom 2.75" Y pipe for the throttle bodies with relocated MAFs.
Can I buy just the modded y-pipe? I 'd like that plus the frozen boost IC. I've already got have the best cooling mods I could buy and an EcuTek tune. Will the injectors Stillen gives you with the kit be able to support the 9psi pulley? Weill the tune have a lot to do with the injectors I use? I think Stillen's kit comes with 600's. should I up them to 750's right off the bat?
#35
He sell the kit as a full, but I'm sure you could speak with him about it. I'll let you know right now that a good chunk of the cost is from the Y-pipe itself. You will be missing out on plenty gains if you stay with the W-A even with the frozenboost IC, since the W-A system itself is weak (regardless if you add the larger IC or not).
Regardless you will need to re-tune.
There's one person getting tuned with the 600cc injectors and pump that came with the Stillen kit, so we should know for sure soon.
#40
Another alternative would be to find a FMIC that is smaller, so you can use the oem crash bar.
I got the same Frozen Boost IC that everyone else had. I'm pretty sure there are people who have put a sensor in the charge pipe in order to read more accurate IATs btw (If you intend on staying with the W-A). There's also an external SD sensor that SpecialtyZ offers for more accurate SD tuning. I didn't run into any issues with my SD tune, but I was on the stock kit the whole time + coolers.
#43
Hey you'll use this one and get the fittings at lowes or HD. Things I was looking at when I had mine was a SVT cobra SC pump and resivour. I found them on the SVT performce wedsite, not to $$$ either . You'll also have to either cut your tow hook off( I did that" or flip the bar upside down to fit the frozenboost I had also liked the idea of the dual fans on the heatexchanger.
Air to Water Heat Exchanger
http://www.lethalperformance.com/sho...ion-fill-tanks
http://www.lethalperformance.com/sho...ercooler-pumps
http://www.lethalperformance.com/sho...-80275ndp.html
#45
Nope, you retain the same pump that comes in the kit. It just gets fitted into the existing system.
You can refer to this diagram, so you can visualize it a lot easier: https://vortechsuperchargers.files.w...iagram_450.jpg
Upscale Speed (05-26-2016)
