ZSpeed CMAK Clutch Movement Alteration Kit CSC Delete
ZSpeed Performance
"CMAK"
Proudly Made in the USA!
CSC Concentric Slave Cylinder Bearing Delete
This is a 100% bolt on kit. Easy to install!
ZSpeed Performance CMAK CSC Delete Kit
The ZSpeed Performance CMAK Deletes the internal Clutch Slave Cylinder also know as a "CSC" and moves the hydraulics to the outside of the transmission for quick and easy change outs if ever needed.
This kit fits
2007-2008 Nissan 350Z
2009-Current Nissan 370Z
2007-2008 Infiniti G35S Sedan
2008-2014 G37 Coupe and Sedan
"CMAK" is currently compatible with South Bend Clutch, ZSpeed Performance, JWT, Spec, Competition, ACT, OEM Nissan and most other single disk replacement clutch kits on the market.
CMAK can be set-up to work with virtually any clutch type! Contact us for details.
Never a need for clutch adjustments, This kit automatically adjusts for clutch wear.
There are no modifications needed to install, Everything bolts on for a simple OEM look install.
CMAK Does not change pedal effort!
Built Solid from the ground up this kit is by far the best on the market for your Z or G!
We offer a Lifetime Structural warranty on this kit!!
ZSpeed Performance CMAK CSC Elimination Kit
"CMAK"
This kit fits
