Drivetrain Reviews of clutches, gear mods, diffs, axles etc..
Review Jsolo spring
Old 03-15-2015, 03:18 PM
Sway_NV
I'm too young to die!
Sway_NV's Avatar
Post Jsolo spring
So I installed my clutch helper spring from Jsolo a few days ago. The stock helper spring was measured at 330 something lbs of force, while the one from Jsolo measures in at only 52 lbs of force.
It took me only 7 minutes to install, was very easy. Hardest part was lining the pin back up after installing it. I would recommend putting a towel or something down, as if you're not super careful it will spring out a few pieces pretty quickly. Anyone that can work a pair of pliers can do this mod, and at only $20, really anyone with a 6mt should do this.
It took me only 5 minutes max to get used to the new spring, though I could instantly tell the difference. It does create small bit stiffer clutch pedal feel (in a good way), while vastly increasing the communication and feel of the engagement point to the driver. It does keep the pedal all the way up when you're not using it, but the first half inch or so does feel as if it has the tiniest bit of play. So I feel an 80 lb spring would be perfect! But I'm really nitpicking at this point.
Highly recommend this mod to any 6mt drivers of the G or Z. Great bang for the buck, and it feels amazing! My clutch actually feels like a clutch now!
https://www.myg37.com/forums/group-b...g-for-6mt.html
^^^ Link for anyone interested.
blnewt (03-15-2015)
Old 12-11-2015, 12:21 PM
4DRZ
4DRZ's Avatar
I agree. This is probably the best bang for the buck part you can get for this car and it is super easy to install too. It definitely makes it easier to find the engagement point for the clutch
Dillybar12
11-01-2015 07:23 PM
si_driver
10-01-2015 09:53 AM
si_driver
09-30-2015 11:46 AM
djdiskino
09-29-2015 07:18 PM
VIVID
09-29-2015 10:58 AM
Quick Reply: Review Jsolo spring
