Sponsor ZSpeed Performance Heavy Duty CSC Clutch Slave Cylinder Kits
ZSpeed Performance Heavy Duty Infiniti G37 Clutch Slave Cylinder
When upgrading your G37 clutch kit the stock PLASTIC G37 Slave Cylinder cannot handle the higher pressures created with even the lightest of aftermarket clutch kits. The Stock CSC will soon fail leaving you sitting with no clutch pressure.
If you are changing your G37 Clutch Kit save yourself the headache and expense of pulling the trans again to change the clutch slave cylinder by replacing it with our PROVEN HD CSC!
High grade seals, Strong bearing, Stainless lines and all metal/aluminum construction insures long life and durability.
We offer a 1 year warranty on this kit if purchased and used with any ZSpeed Performance or South Bend G37 Clutch kit along with the 1 year manufacturers warranty on the clutch kit!
Need a clutch and or G37 flywheel also? We offer great deals on Zspeed Performance & South Bend clutches or ANY brand of your choice in combination with our HD CSC for your G.
