Anybody know oil change DIY's for the 7AT XS coupes??
Old 03-17-2017, 09:19 AM
  #31
dmill86
dmill86's Avatar
Also, these oil filter sockets. Do they differ in size depending on the model? or should there be one generic size that fits most/all infiniti vehicles? would I inquire about this at a nissan/infiniti dealership or can I pick one up at any auto parts store? where did you get yours? Thanks
Old 03-17-2017, 04:54 PM
  #32
JSolo
Just say no!!!!!
JSolo's Avatar
Doesn't the filter on the vg37 attach horizontally?
Old 03-17-2017, 06:44 PM
  #33
Received 4,940 Likes on 4,174 Posts
Yes, that would be correct
I just use my hand to loosen the filters FWIW, if you need a wrench you've over tightened it
But I use those grippy mechanics gloves so that helps since I'm an old fart.
Old 03-17-2017, 07:57 PM
  #34
dmill86
dmill86's Avatar
Good to know. Maybe I will just hold off on getting the oil filter wrench for now.
Old 03-17-2017, 11:19 PM
  #35
JSolo
Just say no!!!!!
JSolo's Avatar
My cheapy latex gloves don't have a good grip. I use a socket to get it off, same to snug it up slightly.
Old 03-18-2017, 06:34 AM
  #36
dmill86
dmill86's Avatar
Thanks jsolo, where did you buy your socket?
Old 03-18-2017, 09:38 AM
  #37
Landshark
Landshark's Avatar
Originally Posted by dmill86
Thanks for the explanation and the picture landshark. Much appreciated. So the drain plug can only be located by "feel"? Wouldn't that make it somewhat tricky to get it threaded back in and torqued properly? Thanks
no, you reach under and just feel the right side of the oil pan to locate it.
there are different sized ones, and "adjustable" ones. i accumulated various sizes over the years for different cars, and happened to have one that worked. all local auto parts chain stores have them, probably Walmart, too.
yes, my bad - just did the 1st oil changes on my car and my wife's car within two days of each other and mixed them up. i needed the socket extension for her car with the vertical filter.
Old 03-18-2017, 01:42 PM
  #38
JSolo
Just say no!!!!!
JSolo's Avatar
No clue. I think it's the same socket I was using on my motorcycle(s). Just take the new filter with you to walmart or pepboys and match it up.
Old 03-24-2017, 03:53 PM
  #39
PandaX
PandaX's Avatar
Where I can find the front diff oil DIY for my car? I don't see there is one.
Old 03-24-2017, 11:32 PM
  #40
Check this one~
https://www.myg37.com/forums/d-i-y-i...ferential.html
