D.I.Y repair engine Fan " Stretch Rail"
Old 02-18-2017, 05:31 PM
rctstdroid1
rctstdroid1's Avatar
My 2 Fan stop workingn and engine over head. ( Not Same Time. last year 1, today 2).
Alway i drive in High Way, and the engine not show overhead Symptom
but Yesterday i driving in low speed 10 MpH aprox 80 min " high Traffic"
and engine over Head Again
In the Obd Tool show 230 ºF. max. with A/C. without A/C the temp warn up.
for Diagnosis the Problem i used Scanner with test component and test
2 fan motor.
the result was thats one fan need small knock for temporaly work.
After remove the 2 fan i opened the motor and i see that the rail for slide the brush is very strech and the spring not has a full force for push the brush with the axis.
the the small screwdriver open de rail for brush slide good.
This was solution.
I dont Know if is desperfect of manufacture? but 2 time in 2 fan, same condition on strech rail.
In the video.
when i Knock the rail and slide.
good look.
remember that for push the axis again you need rollback the 4 brush and keep with the small clip
File Type: avi
