DIY: OEM Aluminum Sport Pedal Installation
#76
Pyroclastic Flow
I still had a bit of trouble pushing the top lip far enough over the brake pedal so I just sat in the seat and used my foot to firmly push it up and over. Locked right in there.
Sean
#78
Ryne, do you think these are worthwhile alternative or cheap junk?
Fuel at Brake Pads Pedals for Infiniti G25 G35 G37 FX35 EX25 EX35 M25 M35 M37 | eBay
blnewt (10-06-2015)
#79
It's the middle of winter right now here in the NE and I drive my corolla daily to work etc. I'll take some pictures when I get a chance. FYI the brake pedal cover was a pain in the butt to get on - requires first removing the rubber pedal thats already on there (easy part) then sheer strength stretching the new one over the bare metal pedal - this probably would have been easier in warm weather. The accelerator pedal slipped over the existing OEM one no problem.
Now I just need to order the dead pedal and I am good to go!
blnewt (07-10-2016)
#82
The dead pedal takes a bit of work, but is definitely manageable. Start by removing the interior door trim by pulling up, it will unclip, and there will be one nut by the fuse panel that can be removed by hand (the bolt hole location can be seen on the trim in the picture below).
This will allow you to pull back the carpet to see (6) pins held in place by metal clips. Using a combination of a flathead scerwdriver and pliers I was able to remove these with a little elbow grease. I decided to clean the carpet with carpet cleaner in the area while I had the chance.
Even with low miles, after 5 years I'm needing a new dead pedal.
Rochester (07-10-2016)
#84
Ok... so I'm new here and to mods in general. Limited budget and I bought these because I thought they looked cool. Did I mess up? Will they go on well. Thanks in advance.
http://m.ebay.com/itm/For-INFINITI-G25-G35-G37-FX35-EX25-EX35-M25-M35-M37-Fuel-Foot-AT-Brake-Pedals-/112186176472?hash=item1a1ed133d8%3Ag%3AUJwAAOSwnbZ YFG5I&_trkparms=pageci%253A8f3f416f-bea4-11e6-ad6f-74dbd1a0e040%257Cparentrq%253Ae77cd19e1580a6a8d0d4 6e9effd86f60%257Ciid%253A5
#86
Ryan, or any one else. On the dead pedal anyone have two protective films to remove? First one is thick, covers the entire pedal. Question is, is there another one over the aluminum only. I got a bubble on mine, see attach pic. The first film has been removed. If there is a second, is it for permanent protection or to be removed also. If it's for protection guess I got a bad one. What y'all think? The bubble I question is in the upper left portion.
#87
Update, guess the aluminum has a protective film over it. The one on the pedal I received had a bubble, discount infinity is going to replace it under warranty. On another note, 60 bucks for the brake pedal pad and foot rest, 44 for a used foot feed on eBay. Great interior refinement for the money.
b2autodesigns
Brakes/Suspension
128
03-24-2018 07:44 PM
david77845
08-10-2015 12:46 AM
slotterjordan
08-10-2015 12:17 AM
