DIY: Headlight restoration
Old 02-12-2015, 10:48 PM
  #31
Gio37
Gio37's Avatar
Originally Posted by tomro99
Okay cool. I'll pick up some 600 just to be safe. Also, in regards to the direction, is it okay to sand up and down. Or by direction, do you guys mean only up or only down?
It doesnt matter which way you start.
Wet sand in one direction. Then the opposite direction with the next finer grit. Very important to always keep it wet and rinse away grit periodically.
g/l
Old 04-21-2015, 09:42 PM
  #32
Bravo at
Bravo at's Avatar
Great DIY...Much appreciated.
Old 04-22-2015, 02:48 PM
  #33
stevo4756
stevo4756's Avatar
Hmmm.
Any update on how well the lights are holding up?
I don't have much oxidation yet, but there are lots of hairline scratches so I'm not sure if I should start grinding away with sandpaper?
Anyone try spraying clear after finished to avoid having to reapply sealant?
Old 04-22-2015, 07:38 PM
  #34
Received 4,940 Likes on 4,174 Posts
Originally Posted by stevo4756
Hmmm.
I think I'd avoid the clear and just deal w/ the sealant every so often since it comes in a pretty big bottle, should hold up real well from all I've read.
BTW, those cracks, here's a thread on those, might be worth a trip to your dealer
Headlight Spider Cracks b/c Vinyl Overlay? - G35Driver
Old 04-28-2015, 12:18 PM
  #35
inyquest
inyquest's Avatar
Hmmm.
I was thinking of trying these
Headlight Film Covers | Lamin-x Protective Films
Old 05-11-2015, 06:38 PM
  #36
twin_snails
twin_snails's Avatar
Gio, where did you pick up the foam polishing bit for the drill? I'm way impressed by your results.
Old 05-11-2015, 09:26 PM
  #37
Gio37
Gio37's Avatar
Here is the LINK
Amazon.com: TCP Global® Brand Premium Detail System 3" Mini-Buffing Pad Kit - 4 Pads, Backing Plate, and 1/4" Drill Adaptor: Automotive Amazon.com: TCP Global® Brand Premium Detail System 3" Mini-Buffing Pad Kit - 4 Pads, Backing Plate, and 1/4" Drill Adaptor: Automotive
blnewt (05-11-2015)
Old 05-25-2015, 02:41 PM
  #38
Gio37
Gio37's Avatar
Hmmm.
wow, I guess I missed this post
anywho, here is a picture I took this morning with my cell phone.
The lights still look pretty good, not as sharp as they looked when I first did the restoration but considering I wash my G and rub on the lens every week I think they are still looking good
Old 08-04-2015, 06:25 PM
  #39
SiKHG37
SiKHG37's Avatar
So I just completed this DIY the only issue is my passenger side is still some what foggy. The driver side came out perfect. Should I repeat the steps again tomorrow on the passenger side?
Old 02-22-2016, 06:55 PM
  #40
desertmike680
desertmike680's Avatar
So I've followed these exact steps multiple times and my headlights are still coming out pretty hazy. I've done this several times and still not coming out crystal clear. I dont get it.
Old 02-15-2019, 02:48 PM
  #41
BluesG
BluesG's Avatar
So, what if inside the headlight has oxidation?
Old 05-17-2019, 04:53 PM
  #42
MusSauce
MusSauce's Avatar
I think removing the lens from the assembly is the only way to attack that issue.
I myself have not done it but I know there are threads out there explaining the process of separating the lens from the assembly.
Old 07-09-2019, 05:01 AM
  #43
18 g37
18 g37's Avatar
Nice DIY
I did the same on my headlight, and also i installed a custom LED bulbs on my G37.
It looks better just like the new car. Very happy.
Why not find a LED bulb to make it perfect.
2K1 6T8
10-06-2015 07:40 PM
takeapieandrun
18
09-27-2015 12:36 AM
Allboutcali
09-26-2015 03:43 PM
pauliewalnutzz
09-08-2015 11:41 AM
Quick Reply: DIY: Headlight restoration
