DIY: Painted headlights
Old 09-11-2015, 11:08 PM
  #31
Received 4,940 Likes on 4,174 Posts
Originally Posted by z_spec
Do I have to use a oven or can I use a heat gun and pry?
I'd just go w/ the oven. I found it was really pretty easy after a bit of a fail on my first light.
The first light I tried prying it up all around the housing edge, this left ugly gouges (can't be seen but I know they're there) all along the edge. The second light was a breeze. I heated the light and just applied force in one corner until I got it lifted enough so I could pull the entire cover off. Once I got the initial lift I put it back in the oven for one more heat cycle, this softened up the rest of the seal so pulling it off was SO much easier and left no marks on the light housing.
Old 09-12-2015, 03:02 AM
  #32
JG_G37
JG_G37's Avatar
I used both an oven and heat gun and I'd lean more towards a heat gun. As long as you heat the headlight evenly it's pretty easy to pry apart.
Old 03-24-2016, 10:29 AM
  #33
vamarris
vamarris's Avatar
Spring is here so it's time for mods. Finally got around to doing this headlight modification and thought I would share. Thanks to everyone for for providing so much useful info! Got this done in a day with several beers and breaks.
Old 03-24-2016, 01:58 PM
  #34
lobuzz311
lobuzz311's Avatar
I posted this in another thread, but I figured it made more sense here, where it would be seen by those doing the headlight mod:
[...]I didn't do any DIY-level documentation, but I've got a few pics from during the process that I'll post here, as well as a few pointers.
I used this post for some inspiration / pointers / visual on the cutoff shield:
https://www.myg37.com/forums/build-t...ml#post3983315
I ended up bugging MaQG37 via PM about his process, which helped me a LOT.
I wet sanded, then used plastic primer and satin black high temp paint. I didn't paint the chrome strip right near the projector, since that's where the bubbling issue is worst. I ended up painting the side reflector, because my trial with Nite-shadez was disasterous.
I modded the shield to get that nice razor's edge cutoff (as shown in MaQG37's thread linked above). I added the STI-R lenses, as well. Those required making a few additional spacers out of a cereal box, using the one already in there as a template.
The halos are the 90mm Morimotos found here:
https://www.theretrofitsource.com/mo...=49387%2C49545
You will need to buy the controller, which gives you the ability to change the colors via remote, change modes, turn on/off, etc. The attachment instructions that come with them are exactly what I used; drill holes on either side and run a wire around it, which gets twisted behind. You can't see it unless you're VERY close, and there is no glue to let go under high-heat conditions. I added JB Weld PlasticWeld to lock the twisted wire behind the shrouds. I drilled through the back of the light housing to run the halo wiring, which I sealed up with more PlasticWeld.
The controller is mounted under the hood on the passenger side, at the top of the fender under the weather stripping. The modules are all zip-tied and HD two-sided taped to various places. There's also a great grounding point right there. The halos are run through a relay that has the trigger wire spliced from the hot on the 12v plug in the console. It gets run through the massive "grommet" at the base of the windshield on the passenger side. This was done because the switched sources in the engine bay are all on computer controlled modules (or something like that), so I didn't want to mess with those.
*** Pro tip: Get a 12v source (I use my R/C battery charger power supply) to power the controller so you can test BEFORE sealing the lights back up!!! ***
And the pics, because... well, yay pics!
And here's a little demo of what you can do via remote (which looks like this): Painted headlights-9dhhwk8l.jpg)
Old 03-24-2016, 08:49 PM
  #35
ShuuraRG
ShuuraRG's Avatar
anyone know which projectors are used for the 2011 G37x sedan? I'm looking to purchase projector shrouds, but I don't know which size to choose:
Matchbox
Mini H1
Mini D2S
https://www.theretrofitsource.com/co.../shrouds.html/
Old 03-24-2016, 09:15 PM
  #36
ShuuraRG
ShuuraRG's Avatar
I think I've answered my own question - Infiniti replacement bulb guide
Old 03-25-2016, 09:53 AM
  #37
MaQG37
MaQG37's Avatar
Matchbox
Mini H1
Mini D2S
Retrofit source sells the G37 projector and they call it just that, G37 projector. Unless it's a shroud made for the G37 projector, it will most likely need some form of cutting to fit snug.
Old 03-25-2016, 10:29 AM
  #38
ShuuraRG
ShuuraRG's Avatar
I'd rather not replace the projectors simply to add a different shroud. I'll find a way to modify the ones I've ordered to fit my existing projectors (a la 180).
Old 03-25-2016, 11:00 AM
  #39
MaQG37
MaQG37's Avatar
I don't think anyone has completely replaced the entire g37 projector, they just make the shrouds fit.
Old 03-25-2016, 11:13 AM
  #40
ShuuraRG
ShuuraRG's Avatar
wish me luck! I should receive my shrouds tomorrow. I'm oping to have enough time to crack the headlights open, paint, and install in time for work on Monday.
Old 03-25-2016, 01:47 PM
  #41
ShuuraRG
ShuuraRG's Avatar
Sorry, I couldn't resist...
Old 11-12-2018, 09:35 PM
  #42
Poulton002
Poulton002's Avatar
Thanks! Results pics
PAIN IN THE A$$$$$$ but worth it!!!. Although I can't fully close my hood now ...gotta figure that one out . But super happy with the results. 2011 Infiniti g37 IPL
​​​​​​if any dork out there does anything with my liscense plate number like a total WEIRDO , I will find you...and I will kill you (in my Liam neesons voice)
Kanwal (02-19-2019)
GeezerB
Car Care & Detailing
12
01-23-2017 07:00 AM
ck1109
10-15-2015 11:06 PM
2K1 6T8
10-06-2015 07:40 PM
stm37s
The M - Spot
10-01-2015 06:53 AM
Chris_M
09-25-2015 08:38 PM
Quick Reply: DIY: Painted headlights
