DIY: Installing window trim vinyl wrap 07+ G Sedans
Old 12-23-2013, 05:20 PM
  #61
Sunny G
Sunny G's Avatar
Thanks Brad I will be doing this as well and ordered a whole bunch of samples to test on my car too.
Old 01-26-2014, 03:35 PM
  #62
Drive Clean
Drive Clean's Avatar
Thanks for the DIY! Ordered a sheet of vinyl and hopefully ill be able to get it to work.
Anyone know how well this stuff holds up in an automated wash?
Old 01-26-2014, 11:49 PM
  #63
Received 4,941 Likes on 4,174 Posts
It holds up just fine under pressure.
Drive Clean (01-27-2014)
Old 02-23-2014, 08:11 PM
  #64
Deelow
Deelow's Avatar
B, do you sell the templates or pieces for the windows and the rear valence? Just curious if I can save myself some time.
Old 02-27-2014, 04:31 PM
  #65
Windows you're on your own The window DIY has the measurements laid out, and although getting everything drawn up & cuto out takes a fair amount of time it's not too bad. The rear valance I only have for the 07-09 Sedans.
Old 03-06-2014, 06:53 PM
  #66
STownSaint
STownSaint's Avatar
Vinyl ordered!
Might be blowing up your inbox in a week or two OP!
Old 03-08-2014, 08:33 PM
  #67
Vinyl ordered!
No prob, I've got faith in you Saint
Old 03-27-2014, 09:28 PM
  #68
zmanfarlee
zmanfarlee's Avatar
Originally Posted by max223
First off, thanks blnewt for this awesome DIY! I decided to give it a go on my 2010 moonlight white sedan and it turned out great. The only trouble I had was working with the vinyl in 20 degree weather.. I just got the car last month so the weather can't hold me back from my Christmas list of mods.
Take a look and let me know what you think. (sorry for the dark garage pics, I didn't want to park it out in the snow )
I have a 2013 moonlight like yours. Dude the black looks amazing! I'm going to do that.... after I buy a house.... hopefully before the second kid... otherwise YIKES
max223 (04-16-2014)
Old 04-13-2014, 12:33 PM
  #69
PERMAT
PERMAT's Avatar
Butchered A, B, & E. Hopefully I can find time next weekend to fix this.
Old 04-16-2014, 08:46 PM
  #70
max223
max223's Avatar
Thanks zmanfarlee! For $15 and about two hours time, I'd say this is definitely a must-have mod for the moonlight white! Along with slightly tinted windows and a midnight grille, it really separates it from the boring chrome-on-white sedan I started with.
Here's a few more pics to help persuade you
Attached Thumbnails Installing window trim vinyl wrap 07+ G Sedans-photo-2-2-.jpg   Installing window trim vinyl wrap 07+ G Sedans-photo-1-2-.jpg
Old 04-22-2014, 03:08 PM
  #71
Need 4 Speed
Need 4 Speed's Avatar
Who would've thought covering up that Chrome Trim would look so hot. Thumbs way up for this.
blnewt (04-22-2014)
Old 04-22-2014, 04:15 PM
  #72
It really is amazing what a $20 transformation can do sometimes. Thanks N4S!
Old 04-22-2014, 05:07 PM
  #73
AroundTheG37
AroundTheG37's Avatar
Glad to see it went well, looks like you did a nice job It's amazing how $20 worth of vinyl can really change the look of your G
Could I wrap the little oem spoiler as well?
Old 04-23-2014, 12:37 AM
  #74
Should be able to w/ a little practice w/ the heat & stretch. luckily it won't take much vinyl so you could have a couple "practice" tries
Old 05-31-2014, 05:30 PM
  #75
STownSaint
STownSaint's Avatar
Finally got around to this, only 1/2 way done but my impressions/comments:
  • The 3M vinyl is a remarkable product and is very lenient on bubbles & creases -- I frequently "blotted" out surface irregularities by simply rolling my thumb over them slowly with slight pressure. The stretch is also useful. AND the gloss finish is very nice looking
  • Before starting, I suggest you mess around with the rubber trim around the windows to get a good feeling of how you can move them around when tucking the vinyl. See which direction is easiest to pull the rubber away from the chrome trim, and how much force is actually required (use as little as possible so you don't pull out or deform the rubber trim) HINT: opening the doors &/or lowering the windows work wonders in some cases, esp the top of the windows
  • Although tools are very useful, use you fingers/fingernails as much as you can to manipulate the rubber trim when tucking. In some instances, I realized I could've just pulled the trim back with one hand & tuck in the edge of the vinyl, but instead I used a credit card and made some marks/nicks in my rubber trim (barely noticeable but avoidable nonetheless) ... only drawback is tips of your thumbs/idex fingers might get sore.
  • Start on the passenger side, may be obvious to some but not to me . Your first shot is bound to have some imperfections, why not put them on the side of the car that you rarely see? My passenger side will undoubtedly be better than the driver side since you learn as you go (I'll prob redo "C" & "D" on driver side eventually)
This was my first time ever working w vinyl, and I'm glad to say mine is coming out pretty good so far. No doubt Blnewt deserves much credit for this writeup (with your permission I can post my version, which is the OP word for word, just organized a little neater)
Question for Blnewt: Can you at all elaborate on technique for trimming of the upper edges of sections "C" & "D"? I kinda just stuck the razor blade in between the chrome piece and rubber seal and slid it down the length of the window, but it didn't come out that clean and in a spot or two I actually sliced a little bit into the rubber. Am I missing something or just need to figure it out with experience?
Prop get to the passenger side during the week
Quick Reply: DIY: Installing window trim vinyl wrap 07+ G Sedans
