DIY: Installing window trim vinyl wrap 07+ G Sedans
Old 06-12-2012, 05:11 PM
R3diK3r0u5
R3diK3r0u5's Avatar
subscribed for future usage
great DIY
Old 07-07-2012, 11:29 AM
Robert_K
Robert_K's Avatar
Awesome!
Old 09-28-2012, 09:00 PM
Damn Dirty Ape
Damn Dirty Ape's Avatar
pics of finished projects?
Anyone in the St. Louis MO region that wants to do mine? Not sure enough of myself and I'd have to see your car to see how good you are
Old 09-28-2012, 10:11 PM
BuckNorris
BuckNorris's Avatar
its actually pretty simple, especially with this diy. blnewt did all the hard work with the measuring/getting it all on one section of vinyl. i was hesitant at first, too. turned out to be easier than i was expecting. plus, looks way better knowing you did it yourself.
Old 10-05-2012, 11:27 PM
dkmesa350z
dkmesa350z's Avatar
Thanks a lot for the DIY. Your measurements made it a lot easier! I opted to use satin black 3m 1080
Old 10-06-2012, 01:44 PM
dkmesa350z
dkmesa350z's Avatar
What a huge difference such a small change can make!
Old 10-06-2012, 08:35 PM
Received 4,941 Likes on 4,174 Posts
Nice job!, Is the satin vinyl between gloss & matte? I've got a big pile of 1080 samples but satin isn't one of them
Old 10-06-2012, 11:53 PM
dkmesa350z
dkmesa350z's Avatar
yes, it is supposed to have a little bit of sheen compared to matte. I believe it is a new product. Ordered from Metro Restyling.
Old 11-14-2012, 11:08 PM
Bota36
Bota36's Avatar
I finally made the decision to give this DIY a try. Thanks blnewt for the great write up.
Before
After
Next up...midnight grill. Little worried about that one but willing to give it a try.
ctyke (07-08-2016)
Old 11-15-2012, 12:19 AM
Nice work Bota, looks like you did a great job
Old 11-15-2012, 03:37 AM
Bota36
Bota36's Avatar
Thanks blnewt. I found out on the 2nd side I did, it was easier to do bottom of the top trim with the window down. It allowed me to tuck the vinyl easier because the rubber trim would bend out of the way just like the top rubber.
All in all it's a such a great DIY to change the look...and you can always go back to chrome if you want. I'm just trying to figure out how to do the grill now. I'm probably going to try with the grill left on but I want to remove the Emblem first. I'll figure that part out but I want to do some more research on the subject first.
Did you take your grill off or did you leave it on? Did you also remove your emblem?
Old 11-15-2012, 09:55 PM
I placed the vinyl sheet on the grill, tacked the front surfaces down lightly once I had the vinyl centered just right then removed the grill. I removed the grill first to remove the emblem, then just lightly bolted it back on to place the vinyl. You'll want to remove the grill to be able to fully wrap the edges that go between the bumper and also heat & seal the back edges and it'll allow you to trim around the vertical plastic supports between the grill slats. I've wrapped a couple 2007-2009 sedan grill but haven't done the 2010+ grills yet so I'm not able to provide specifics on your grill. Look forward to seeing pics of your grill when you get it done. You really need to heat the vinyl pretty good to get enough stretch to allow you enough vinyl between the slats. You want to cover the upper top edges of the slats enough to go fully back to the back edge w/ the vinyl. The underside of the slats only need about 1/8" to wrap on the underside. Not sure, but if your grill has some slats that have a narrower gap I'd start w/ those first so you'll get an idea how much you need to heat & stretch before moving to the tougher slats w/ the wider gaps (which require more vinyl area).
HTHs
Old 11-15-2012, 11:19 PM
dkmesa350z
dkmesa350z's Avatar
Night and day difference on black Gs, that looks awesome.
Old 04-27-2013, 04:23 PM
  #29
jktinen
jktinen's Avatar
****ed this one up... gonna have to leave it up to the professionals.
Old 07-08-2013, 09:45 PM
  #30
bat6wc
bat6wc's Avatar
thanks for the writeup newt. I purchased some vinyl and Im going to give it a shot, and if not, the pros will do it. Im also doing the top and bottom chrome strips on the oem midnight grill.
Quick Reply: DIY: Installing window trim vinyl wrap 07+ G Sedans
