DIY: Steering Wheel Trim Removal/Replacement DIY
Old 05-11-2012, 04:05 PM
dillyyo
dillyyo's Avatar
I'm assuming that you can only refinish the existing trim and not get a new one, as my guy at Nissan could not pull up a parts number other than the whole steering wheel assembly? Any other ideas for wraps or finish for the trim?
Old 05-11-2012, 04:39 PM
htran16
htran16's Avatar
I don't think you can order the trim piece only. When I brought my car in to have them replace my chipped trim (under warranty), they replaced my whole steering wheel.
Old 05-14-2012, 01:27 PM
mikaly
mikaly's Avatar
Apparently Infiniti/Nissan provides the trim pieces separately now!! (check next post).
Old 05-22-2012, 03:05 AM
harp00n
harp00n's Avatar
ok, WHO IS THE MASTER OF THE INFINITI PART NUMBERS??? Yes, it's ME!
Partnumbers of the trims are:
Nissan 48463-JK06A LIDSTEERING,RH - Black (only cruise-control hole)
Nissan 48463-JK06B LIDSTEERING,RH - Beige (only cruise-control hole)
Nissan 48463-JK07A LIDSTEERING,RH - Black (both cruise-control and Navi/Bluetooth hole)
Nissan 48463-JK07B LIDSTEERING,RH - Beige (both cruise-control and Navi/Bluetooth hole)
And yes, dealers can't find these numbers in the Nissan Fast catalog, though you can order them. Some strange Nissan/Infiniti decision...
The following 11 users liked this post by harp00n:
Baadnewsburr (03-18-2015), Bravo at (08-19-2018), handleandrew (08-12-2014), Jreal24 (03-01-2014), Kanwal (02-19-2019), kennyz424 (02-20-2016), Loki_D_Wolf (06-01-2015), Presto (09-14-2014), Q8y_drifter (10-27-2013), spinn (03-21-2017), Zelf24 (05-30-2013) and 6 others liked this post. (Show less...)
Old 05-22-2012, 04:14 AM
dtran2714
dtran2714's Avatar
^^^Good work bro. How much does the trim cost?
Old 05-23-2012, 01:21 PM
harp00n
harp00n's Avatar
just 7$
Old 05-23-2012, 05:30 PM
vsiev
vsiev's Avatar
Originally Posted by harp00n
just 7$
Wow that's cheap....Where can I get one? Will the dealership have them in hand or do I need to order it online?
Old 05-23-2012, 05:32 PM
dtran2714
dtran2714's Avatar
just 7$
Dirt cheap! I'm gonna get one to replace my scratched up one.
Old 05-23-2012, 08:25 PM
TwoThree
TwoThree's Avatar
Awesome find harp00n! At that price it makes me want to order one and wrap it in Di-Noc just to have as an option and see how I like it. With a spare you could switch it up whenever.
Old 05-24-2012, 12:14 AM
mikaly
mikaly's Avatar
Wow! No Infiniti dealership I've interacted with so far said they'd sell it separately. Great news, and good find!
Old 05-24-2012, 08:52 AM
harp00n
harp00n's Avatar
on g35driver people say, that dealer refused to order this part, because of Nissan/Infiniti politics.
though, I'm sure you can find some company that would import it from UAE (I ordered it from there) or Japan.
Old 05-29-2012, 08:18 PM
mikaly
mikaly's Avatar
I'm going to Korea next week so I'll check to see if Korean dealerships sell them separately.
Old 06-21-2012, 01:22 PM
burunet
burunet's Avatar
The dealers won't sell it anymore, they'll only sell the entire assembly with the wires and buttons for $250, but orderinfinitirpart.com does for $8.23. Just put the part number and boom....
Old 07-13-2012, 11:08 PM
  #29
606zpx
606zpx's Avatar
Are the part numbers for the same rubber coated trim piece? I think newer cars have hard plastic that is not rubber coated.
Old 09-02-2012, 06:22 PM
  #30
Brian Thompson
Brian Thompson's Avatar
I did this DIY yesterday and accidentally pulled the cover off of the clockspring (the piece with the white **** and and connection to steering wheel controls). I tried to repack it myself and ended up bending the fragile ribbon and received an ABS warning light. I have a new clockspring coming later this week.
My problem is that now I'm seeing all kinds of problems beyond the ABS warning light.
1. "VDC Off" & "Slip" lights illuminate and stay lit every time car starts. I've read this is possibly related to low brake fluid or a sign that I need to replace my brake pads, which makes sense since the rear brakes have been squeaking lately. It's just strange that it started at exactly the same time as the ABS problems.
2. I get the "AFS Off" light after driving for a few minutes. This one is tricky. I think it may be that I didn't line up the steering wheel exactly where it should be. I'll try aligning it again when I fix the clockspring later this week.
Any way, I wanted to see if anyone else had experienced any of these issues and if they had any tips on what could be causing these issues.
-Brian
Quick Reply: DIY: Steering Wheel Trim Removal/Replacement DIY
