Transfer case oil change plus front differential
Old 03-18-2016, 10:10 PM
  #46
Rr1982
Rr1982's Avatar
Yah Mobil 1 is full Synthetic.thanks for input.
Old 03-25-2016, 05:41 PM
  #47
Landshark
Landshark's Avatar
what does the dealer whack you for transmission fluid replacement (and transfer case)?
i did power steering fluid and am going to do the diffs myself, but i'm feeling lazy about the transmission.
Old 03-25-2016, 05:48 PM
  #48
Rr1982
Rr1982's Avatar
I'm not having the transmission fluid changed,just the transfer case and differentials,doing it myself.
Old 03-25-2016, 09:05 PM
  #49
Landshark
Landshark's Avatar
sorry, i wasnt asking you in particular, just anyone who has had the dealer do the trans/transfer case fluid. wondering if they get ridiculous with the price ...
Old 04-04-2016, 12:23 AM
  #50
tite_tite
tite_tite's Avatar
i'm looking to change my rear differential fluid. this transfer case is "front differential"... does this only applies to G37 X model or are they on all G37? i didn't get a chance to look at my G37 no X model. thanks in advance.
Old 04-04-2016, 12:29 AM
  #51
Rr1982
Rr1982's Avatar
Non x should only have rear differential,no transfer case and no front differential.
tite_tite (04-04-2016)
Old 04-16-2016, 01:45 PM
  #52
MH2013
MH2013's Avatar
I think I broke the oil pressure switch trying to break the full plug loose on the front dif.
Does anyone know if this is a Nissan only part? And is it safe to drive until I can get it replaced? Sorry for the pic quality not much room to get a decent angle.
Old 04-16-2016, 02:16 PM
  #53
MH2013
MH2013's Avatar
I got lucky the local Nissan dealer has one in stock!
Old 04-17-2016, 08:04 PM
  #54
Rr1982
Rr1982's Avatar
Glad to hear it will be OK!
Old 04-25-2016, 01:00 AM
  #55
Rr1982
Rr1982's Avatar
Just finished rear diff,trans case and front diff. The rear is only listed as 3 pint refill, but it took more than that to reach the fill hole.
Old 05-12-2016, 04:30 PM
  #56
ddoctorisin
ddoctorisin's Avatar
Price for Rear Dif and Transfer case Oil
$250 In Guelph $300 IN Oakville. Just called them as I have no where to do it and I bought the car used and drive it how you should (Hard AF)
Old 05-12-2016, 04:47 PM
  #57
Rr1982
Rr1982's Avatar
If u have money to blow,do if not do it yourself for about $50
Old 05-12-2016, 05:07 PM
  #58
ddoctorisin
Thanks great point! It'll take me hr each way to Guelph or Oakville (love GTA traffic) plus wait time for them to do it. Looks like I'll be finding a place to do it Thanks Buckets for the killer DIY
Old 07-02-2016, 11:59 PM
  #59
defektion
defektion's Avatar
Thanks OP!
I managed to get around doing this earlier today! I used Redline Redline 75W90 for both my front & rear diffs and Redline D4 ATF(Matic J equivalent) for my transfer case. The total cost of my doing this was about $100 bucks for the fluids + $12 for the 10mm hex socket and a 3-4 hours.
The only issue I found was trying to get a torque wrench on the fill bolt (because of the oil pressure switch). I also under torqued it so I had to jack the car up again and torque it with 26 ft lbs not 26 in lbs (woops).
I also didn't replace the gaskets but if I could do it over again, I would replace it with new gasket for some peace of mind.
Old 03-14-2017, 12:20 PM
  #60
dmill86
dmill86's Avatar
Hey Buckets, not sure how old this thread is but I really hope you (or anyone else familiar with this DIY) can take the time to read this because I need your help. Any advice will be greatly appreciated.
Keep in mind I am a total NOOB! Based on the pics I don't really have any idea where the front diff drain and fill plugs are located but I'm sure once I'm under the car I will figure it out.
OK. So assuming I have the panel removed and have the front diff fill and drain plugs exposed. I would then remove the front diff drain plug and let the fluid drain out until it reaches a slow drip. I would clean the drain plug and screw it back in 2-3 times to ensure all the sediment is out. Once the reservoir is empty and plug cleaned, I would then screw the drain plug back in (with proper torque) and pump the new fluid into the fill plug until it slightly poors out the fill hole (ensuring its full) now would I drain it again ensuring all the old fluid is gone? and repeat the process? and is this the same process for the rear diff? Thanks in advance for any help/advice on this DIY.
Quick Reply: Transfer case oil change plus front differential
