DIY: Sedan interior and exterior LED bulb installation guide
That looks hot. You should check out LEXEN AUTO Online Store, Super Bright LED Lights, Car LED Bulbs, Auto LED Light Bulbs, LED Headlights, LED Tail Lights, Lexen they got good prices on LED's.
Does anyone know if 2009 G37s can do the theater light thing (where the lights turn off gradually)? I was driving a loaner car today 2012 or 2013 G37 sedan and noticed they have that feature. I had swapped out my interior lights for LED lights a while ago. They currently don't do the theater thing with my new LED lights but I can't remember if they ever did it with the original lights.
thanks!
thanks!
Door courtesy lights:
The housing will pop out, you need to unplug it and use the screw driver to pop the outside cover off and expose bulb.
Great write up, don't mean to be ignorant, good at breaking fragile things, is there an easy way to take off the lens that protects the bulb without breaking it, Car is new, would rather not break anything already, I've been delicate with it but that got me no where, thanks man!
I know your question is a couple months old but you just have to gently pry each of the 4 clips until it pops off. Sometimes while prying one clip another one will pop itself back on, just keep working at it.
I'm having trouble getting the trunk light cover off. I can see that it's supposed to open from one side only but no matter how I squeeze and pull I can't seem to get it open without feeling like I'm going to break it...
All those interior led replacements are relatively easy. Just use a small flat head screw driver on the four corners of any interior light and the shade Will pop right off. The hardest one is the glove box light. I used this thread as my blueprint.
https://www.myg37.com/forums/showthr...597&styleid=52
Still looking for an answer to my post above about the 921s in the reverse light housing!
Have you had any problems with the Map lights staying up? Mine keep falling down and you can see the dots and I don't like that. If you have, have you come up with a way to keep them up?
Hello, does anyone know where I can buy the lower door casing? The plastic/glass piece of the light came out and when they slammed my door it broke the glass, bulb and part of the encasing.
