DIY: Cabin Air Filter Replacement Video
#33
The trick is to have a long MAGNETIC screwdriver for those deep screws. I tried using a standard screwdriver and accidentally dropped one of the screws into the abyss... It's gone now.
#34
Did this today. Video was awesome help. Yes it's definitely easier with the right tools which I did not have but was able to manage with a regular screw driver. Had a little bit of a fight dislodging the glovebox after all the screws were removed but all in all went well. Thanks to the OP.
#35
My filter should arrive soon and this should help for the installation.
Too bad its not like my wifes '03 Accord. No tools needed , no screws to loose.
Open the glovebox , squeeze the sides , drop the door and replace the filter , close the glovebox. A 30 second job.
#36
I changed my filter the other day, used a socket wrench with extensions and the phillips bit. Pretty easy job, although I had the squeeze the bracket closer to the left side of the glove box in order to get the rear screw to go back in easily. I bought a Wix filter and there were no directional arrows so I'm assuming it can be put in either way.
#41
Followed the Filterheads video on youtube and it was easy! Had a bit of trouble screwing back the glove box into position for some reason :s First time for everything!
#42
I went with the Fram Fresh Breeze from Rockauto (FRAM Part # CF10743 ). It's carbon charged and also used baking soda. $20 plus shipping, working out well so far. To make the shipping cost worth it, I also ordered some Wix engine air filters and Bosch oil filters at the same time.
