DIY: Changing rear differential gear oil
#121
I purchased some MotylGear 75w90 for my front and rear diffs (12 g37x sedan).
This has some different properties than Motul Gear 300 and I was wondering if it still ok to use? Anyone have experience with it? A lot of the viscosities appear similar.
Motul Gear 300 Properties:
Specially formulated for racing and high performance cars: Circuit, Rallye, Raid...
All gearboxes and hypoï d rear axles without limited slip system.
All types of cars: Circuit, Group A, Rallye, 4WD, passenger cars...
For hypoï d rear axle with limited slip differential, use MOTUL 90 PA or HYPO SYNT LS.
Meets SAE 75W to 90 manufacturers' requirements.
STANDARDS: API GL4 and GL5 / MIL-L-2105D
Very high lubricating power which decreases friction and wear.
Very easy gear shifting.
Thermal stability under high temperature.
Unshearable oil film, even under extreme working conditions.
Extreme pressure, Anti-wear, Anti-corrosion, Anti-foam.
100% synthetic lubricant.Multigrade.
Viscosity grade SAE 75W-90
Density at 15°C (59°F) ASTM D1298 0.868
Viscosity at 40°C (104°F) ASTM D445 105 mm2/s
Viscosity at 100°C (212°F) ASTM D445 14.2 mm2/s
Viscosity index ASTM D2270 140
Flash point ASTM D92 200°C / 392°F
Pour point ASTM D97 -39 °C / -38°F
MotylGear 75w90 Properties:
Specially recommended for gearboxes hard to shift
All types of cars: Circuit, Group A, Rallye, 4WD...
In gearboxes and rear axles with limited slip system, use MOTUL 90 PA or HYPO BM LS.
In automatic gearboxes, use MOTUL DEXRON IID or MOTUL TRANSMISSION FLUID.
Meets SAE 75W to 90 manufacturers’ requirements.
STANDARDS API GL4 and GL5 / MIL-L-2105D
Very high fluidity under low temperatures which allows easier gear changing.
Density at 15°C (59°F) ASTM D1298 0.883
Viscosity at 40°C (104°F) ASTM D445 81 mm2/s
Viscosity at 100°C (212°F) ASTM D445 14.5 mm2/s
Viscosity index ASTM D2270 188
Pour point ASTM D97 -48°C / -54°F
#123
I thought I would try again to get my answer before I put Mobil 1 Synthetic Gear Lube LS 75W-90 into my front and rear differentials. Is this oil safe to use in my G37x?
#124
ricpaq (09-03-2016)
ricpaq (09-03-2016)
#127
Did mine today. Nice and easy. Toughest was cleaning up pump
I started with car jack, but ended up removing it and finishing everything without it. Car jack was in a way so it kind of bothered me.
Thanks a lot for the DIY.
#129
Originally Posted by inf4mOus
I have read every post in the thread but yet still have trouble deciding the best replacement oil.
I am deciding between
OEM
Mobil 1 Synthetic LS 75W90
Amsoil
Suggestions??? I have a 2008 G35 6MT. I believe this hasnt been changed in 50k miles
OEM
Amsoil
#132
Has anyone used 75w140 in cooler climates? I lived in the PNW and I rarely drive the car since it’s a weekend car. I ordered the wrong viscosity and hoping it would work without returning it but if you guys think it’s going to cause some issue then I will switch it out.
#133
Dont forget washer..
Dont forget washer & let it drop in pan. Almost forgot bout them changing it today
