DIY: Reversing the shift direction for 5AT
#31
In the first picture where you move the shift boot down, how do you get the metal ring that sits between the boot and the actual shift **** to move down. Mine seems to be held by something but wiggles. I don't want to break it
#33
I understand that part, i'm talking about how you get to the clip. the boot doesn't just slide down.........something holds the boot against the shift ****. i want to know how you get the boot to slide down so that you can see the clip.
#34
if your trying to get the boot down so the clip can be seen then you would have to pull the boot down. its really tight but with a little force the boot will
pop out and slide down. ill make a short clip of this diy project just really busy. please be a little patient.
#35
12Fear, did you run accross anything in your investigations that looked like a shifter tie in for the paddle harness? I want to add paddle shifters but my car model did not come with that part of the harness in the steering column. I'm trying to find a clean way to add them.
#36
12Fear - I got a message saying you posted the following:
"here is a wire diagram that could be usefull to you" , but when I link to it, I can't find it at the end of the thread. Would you mind either reposting or attaching to a PM?
Thanks
Thanks
#39
no thats the normal operation already, Im making it when your shifting down on DS mode it will upshift then pushing foward will downshift. It works great for me.
#40
Sorry to dig up an old thread, but has anyone done this to the 7AT yet? I've checked the plugs & the colour/location of the wires are different on the 7AT than the 5AT. Couldn't find a service manual on the net for the sedan/coupe with 7AT to check the wiring diagram...
If someone has successfully done this on their 7AT which wires do you switch out?
#42
Someone used to BMW's manual mode would probably be in favor of this mod.. Still pointless IMO I don't understand why it'd be cooler to move the shifter **** downwards to upshift. Besides wouldn't it be more logical to move the shifter ****
UPwards to UPshift and
DOWNwards to DOWNshift lol
#43
#44
For me, it's the feeling of going with the sensation of being pushed back into my seat that makes pulling equate to upshifting. Likewise, as I brake it feels more natural to push forward to downshift as momentum is pushing me forward in a rapidly decellerating car.
BTW I have a 7AT and would LOVE to get a DIY on this mod as well as a way to reverse the "+" & "-" on my shift plate.
#45
