DIY: Easy Way to Reset ECU without battery disconnect
Old 08-28-2015, 01:07 PM
  #181
AloRock
AloRock's Avatar
Sorry, I didn't see the first reply you had. Is there a Nissan dealer closer, might be worth a try.
Nobody who knows how to reset the Intouch system ?
This is just an computer. Every computer has an option to factory reset. But how ??
Old 11-30-2015, 06:42 PM
  #182
runit
runit's Avatar
Hey everyone. New to the forums, 2011 G37S Sedan 6MT.
I did the ECU reset (the 370z one, 10s instead of 7, 12s instead of 10 etc etc).
Finally got it flashing, and I think I got it to work. However, now I notice when I turn my car on, press the VDC Off button, the VDC actually keeps staying on... I have to stop, turn the car off completely, and then press the VDC Off button again for it to actually turn off. Kind-of a pain, I'd like to get it back to how it was before... do you recommend I do the ECU reset again? Anything like this happen to anyone else?
Thanks
Old 03-24-2016, 11:37 AM
  #183
Stone27
Stone27's Avatar
Thank you so much, this still works
I tried this on my 09 g37x and it worked the first time. I used the music track time for counting made it easy. So cool the infinitis have these features.
Old 03-28-2016, 06:44 PM
  #184
G37sGraphite
G37sGraphite's Avatar
I just disconnected my battery because its new to me to reset it. I left it disconnected for 12 hours and when I reinstalled the battery cables etc. my windows did not need resetting ...is that normal. I thought if you disconnected the battery and reset the car it would make the windows need to be initialized??
Old 06-24-2016, 08:43 AM
  #185
bikezilla
bikezilla's Avatar
Originally Posted by South3rn
For those of us who have never done this before, I have made a minor, but important, change
1. Push start button twice to get - Ignition "ON", count to 3.
2. Depress/Release gas pedal 5 times - hard and fast.
3. Count to 10 (not 7!) and fully depress gas pedal.
4. Count to 12 (SES should be blinking), release gas pedal.
5. Count to 10, depress gas pedal.
6. Count to 10, release gas pedal.
7. Turn off ignition, then start engine. ECU reset is done!
Believe me it doesn't work using the brake pedal no matter how many times you try it or what timing you use!
When you assume. you make an *** out of u and me. LOL!
I tried it this morning just before leaving for work. Got it on the first try.
If you don't count the 2 times I was pressing the brake instead of the gas, and the time I lost count.
Otherwise, it worked like a charm
The first two WOTs were sluggish, then the car was perfectly normal. No difference AFAIK. Drove it hard for the hr+ commute.
Tonight I install my R2Cs.
Old 11-24-2016, 02:49 AM
  #186
Rr1982
Rr1982's Avatar
Will this ECM reset delete an UPReV Tune?
Old 03-06-2017, 01:42 PM
  #187
Xyrium
Xyrium's Avatar
I performed the idle reset process and it seems to have smoothed things our after a filter change, and MAF cleaning. I probably won't know until I'm in traffic tomorrow. If nothing changed, I'll do the full relearn this weekend.
Old 03-13-2017, 05:02 PM
  #188
Mattlorentzoe
Mattlorentzoe's Avatar
^^^^^^thisssssssss. Anybody???
Old 04-03-2017, 01:48 PM
  #189
DJMAC
DJMAC's Avatar
Resetting the ECU or pulling the battery will not remove the Uprev tune. It is stored in the ROM and I think can only be wiped if the dealer goes and updates the actual ECU firmware. I tested my maps out to make sure and they were all fine.
http://uprev.com/UpdateFiles/softwar...er%20Guide.pdf
xorbitman (04-14-2019)
Old 06-05-2017, 04:31 PM
  #190
BigEDGE02
BigEDGE02's Avatar
Does anyone know if this will work on the 3.0t?
Old 06-15-2017, 10:06 AM
  #191
g37x2013
g37x2013's Avatar
I found this set of instruction on the Infiniti Q50 forum. Otherwise you can try what is above on this thread OR I have always used this video on my G37 and it works (might be similar to this thread but the video is easy to follow):
Hope this help you out.
"want to reset the ecu to get the peppiness back in the car after the break in and first oil change. was following the instructions below, there are other versions with differing times between presses and how long to leave it untouched so i took an hr and tried every one with a stopwatch today. The lights never flash so i was assuming that it might have possibly been changed for the new motor
2. Depress/Release pedal 5 times - hard and fast.
3. Count to 10 (not 7!) and fully depress pedal.
4. Count to 12 (SES should be blinking), release pedal.
5. Count to 10, depress pedal.
6. Count to 10, release pedal.
7. Turn off ignition, then start engine. ECU reset is done!"
Old 11-17-2017, 05:15 PM
  #192
Cwickenstein
Cwickenstein's Avatar
Thank you! I had to replace my stock mufflers and added 3" pipes from the resonator to a 3" inlet (4" out) on my new high-flow, N1 style mufflers. The process worked as described. I am now *retraining* my ride. It seems to have been successful as the jumping, lurching and random downshifts seem to have disappeared or at least mellowed. I'm only about 20-30 minutes of local, in-town traffic in, so I'm hoping by the weekend to feel the difference.
There's a quick, not too instructional vid by someone on YT, but I'll try to make one with better audio, correct orientation video and perhaps the above referenced instrux included.
Thanks!
Old 04-25-2018, 05:07 PM
  #193
Superjay
Superjay's Avatar
for those who can't get this one figured out, and need to reset the ECU by disconnecting the battery, you don't have to wait hours on end to get it to reset. Disconnect the positive terminal and touch it to the negative terminal. You will see a small spark. This is all the capacitors draining in the computers. It is safe, and how I've been doing it for years. In addition to being an EET, I am also MECP and ASE certified.
Discharging all the caps this way means you can disconnect, drain caps instantly, reconnect, done. It takes all of 40 seconds.
Kpmikey808 (10-05-2020)
Old 01-17-2019, 01:35 AM
  #194
gtownrsx
gtownrsx's Avatar
wow - this worked like a charm and throttle response is definitely noticeable. just got a 2013 g37 and this was the first thing I did, made a heck of a difference.
Old 04-13-2019, 11:58 PM
  #195
xorbitman
xorbitman's Avatar
Will this reset the flashing airbag light after a batter drain and recharge?
Quick Reply: DIY: Easy Way to Reset ECU without battery disconnect
