DIY: Easy Way to Reset ECU without battery disconnect
Old 04-09-2013, 02:58 PM
  #151
hhyder
hhyder's Avatar
i'm gonna have to try this today... maybe play the video at the same time
Old 06-01-2013, 09:37 PM
  #152
DJE44
DJE44's Avatar
Worked like a charm. Just follow this exactly along with him:
Old 06-15-2013, 10:10 AM
  #153
J32A2
J32A2's Avatar
FWIW, with my previous car there were similar discussion about ECU resets after non-forced induction engine mods. Some said it makes a difference and others said no. The proof was attaching and OBD2 connector pre and post mods. I can tell you that there can be a difference. It depends on the car, the mods, how the person drives the car and how many miles have been driven.
An easy test would be to connect an OBD2 monitor pre and post mods.
Originally Posted by oliveview
Not to rain on anyone's parade, here, but is there any hard, empirical data to indicate that resetting the ECU does anything, at all? Again, not seat of the pants, as that's a useless measure of anything as subtle as this would be.
The main reason I ask, is that my understanding is that the ECU on this (or any modern car, for that matter) is continually modulating and updating the data it processes, based on current driving conditions. We're talking about milliseconds, and seconds worth of evolving data. It doesn't compile days, weeks & months worth of information. That would provide no advantage to the car's control systems.
Quite fundamentally, THAT is the whole reason that modern cars even have the digital ECU systems, so that the engine and associated systems can nearly instantaneously monitor what is happening, and adjust as needed.
Old 06-21-2013, 10:56 PM
  #154
scoobyalty
scoobyalty's Avatar
Super easy if you just follow the directions. Thanks.
Old 03-27-2014, 09:29 PM
  #155
Chekz
Chekz's Avatar
A little update to those having issues with this. I tried doing it this way 20 times with no success, only slow blinking that's it. Then I tried this method over on the370z forum and it worked.
1. Push start button twice to get - Ignition "ON", count to 3.
2. Depress/Release pedal 5 times - hard and fast.
3. Count to 10 (not 7!) and fully depress pedal.
4. Count to 12 (SES should be blinking), release pedal.
5. Count to 10, depress pedal.
6. Count to 10, release pedal.
7. Turn off ignition, then start engine. ECU reset is done!
maduko (05-30-2015)
Old 06-27-2014, 10:42 AM
  #156
SoonerChris
SoonerChris's Avatar
Followed these instructions and reset ECU on first try.
Old 09-07-2014, 07:49 AM
  #157
ggggg37
ggggg37's Avatar
isn't it easier to just disconnect de battery? is there any difference to the results by disconnecting the battery or doing this trick?
Thanks
Old 10-28-2014, 03:39 PM
  #158
G37Xtreme
G37Xtreme's Avatar
Thanks
If you don't mind losing all sorts of presets then yes. I've even read recently that your window's "auto-up" feature goes away if you disconnect the battery, and that you have to do some simple programming on each window to get it back.
So this will avoid all sorts of issues, and also let you reset the ECU without needing a single tool or getting out of the car.
Old 10-31-2014, 11:36 PM
  #159
Jperrone
Jperrone's Avatar
I notice that there is a frequency that the light is blinking. The first time it starts, its rather slow; then it goes to fast
It also makes a pause in flashing, at about 7 seconds. I think all these variations are indicating something, but not sure what.
I timed the "10 second" wait in the video; close but more like 11 seconds. That would indicated the 370Z timings, which seem to be a bit longer, are preferred.
Still having difficulty getting this to work using the 370Z guidelines... I wish I knew what the light flashing timings meant
Regards
Old 12-12-2014, 12:20 AM
  #160
chen3454
chen3454's Avatar
Does this reset the hard top as well if it says "roof in operation on dashboard"
Old 12-12-2014, 12:22 AM
  #161
chen3454
chen3454's Avatar
Hi would this reset the "trunk in operation" warnig that apprears on the dashboard for a g37 convertible
Old 12-22-2014, 02:47 PM
  #162
South3rn
South3rn's Avatar
For those of us who have never done this before, I have made a minor, but important, change
2. Depress/Release gas pedal 5 times - hard and fast.
3. Count to 10 (not 7!) and fully depress gas pedal.
4. Count to 12 (SES should be blinking), release gas pedal.
5. Count to 10, depress gas pedal.
6. Count to 10, release gas pedal.
Believe me it doesn't work using the brake pedal no matter how many times you try it or what timing you use!
When you assume. you make an *** out of u and me. LOL!
The following 2 users liked this post by South3rn:
rdog (02-02-2015), therzdae (07-07-2015)
Old 01-16-2015, 01:56 AM
  #163
G37sTimCA
G37sTimCA's Avatar
After doing this several times without success, I took both my battery cables off the batter and touched them together. Its an old dealership trick to clear out the memory. Unfortunately, like anything, it would erase all settings.
To my surprise, after touching them together for 10 seconds and jumping into my car to start setting radio stations, etc...all was retained. And best of all...no more check engine light.
blnewt (06-27-2015)
Old 02-02-2015, 07:01 PM
  #164
rdog
rdog's Avatar
I did this over the weekend and worked perfectly the first time. Car drives much better now as I did buy it used.
THANK YOU for the post South3rn
2011 vert base.
Old 02-11-2015, 03:50 PM
  #165
aussiedave79
aussiedave79's Avatar
This is great to know and saved me a bunch of times! Thanks.
Quick Reply: DIY: Easy Way to Reset ECU without battery disconnect
