Gas vs. electric power washing + foam cannon for car washing
Old 02-21-2017, 09:23 AM
nfsG37
nfsG37's Avatar
I'm debating between a gas vs. electric power washer for car washing (with a foam cannon), plus cleaning sidewalks, wooden decks, and vinyl siding around the house. From what I have read and/or seen when researching forums/Youtube videos, the foam cannons appear to be better suited with a gas power washer instead of the electric, in part due to the higher gallons per minute capabilities of the gas power washers.
Two models I am comparing are the Generac (model 6922) 2800 PSI with 2.4 GPM, and a SunJoe SPX3000 Electric power washer (2030 PSI with 1.76 GPM). Please let me know your experiences with power washers, and power washing cars.
Old 02-23-2017, 09:17 AM
The Pope
The Pope's Avatar
I'd like to know as well......
Old 02-23-2017, 09:36 AM
nfsG37
nfsG37's Avatar
I posted this question on another website forum and got quite a few responses. I also read many online reviews and watched a few Youtube videos. From what I gathered, it seems that an electric power washer will do an 'OK' job with most foam cannons, but a gas power washer will do a 'great' job with the a foam cannon. The higher GPM and PSI of a typical gas power washer should allow for a thicker foam to be applied.
I went ahead last night and ordered a Chemical Guys Foam Cannon, Honeydew Snow Foam Auto Wash, and a Generac 2800 PSI, 2.3 GPM gas power washer. I plan on using the power washer around the house for cleaning other stuff to, so it will be a benefit of not having to use an electric cord everywhere I use the power washer. The downsides are going to be noisier operation and a little more maintenance than an electric model.
Once I receive all of the items I ordered, I'll post a few pictures and let you know how well the pressure washer/foam cannon perform.
Old 02-23-2017, 10:29 AM
Lt8Che
'Cuz Racemod-erator
Lt8Che's Avatar
I bought an electric one off Amazon a while back for a great sale price but it's a hassle with the hoses and power cord. If I had to buy again, it would be gas powered.
Old 02-23-2017, 10:32 AM
If you plan to use it for anything more than washing the car, the gas powered unit was the way to go without question.
Old 02-23-2017, 02:06 PM
LateApex
LateApex's Avatar
This is an interesting thread to me since I have a very nice 3300psi/3gpm (with the Cat pump) gas-powered model now. I'd like to explore the foam cannon wash route but I was looking at very small electric units because getting this big gas unit in and out to wash the cars once a week would be a PITA. Space is at a premium in the garage so it's kind of locked in... I have to move the generator a bit to squeeze it out, and to move the generator, I have to move one of the kid's quad. It's fine for the 4 or 5 times a year I use it on the deck, house, driveway, etc. but... weekly, no way.
So I was looking at very small, lower powered electric units that would fit on the shelf. I called Chemical Guys. They indicated that the EQP321 would work fine with the electric unit, though maybe not as quickly or efficiently as with my gas one.
Old 03-06-2017, 11:56 AM
nfsG37
nfsG37's Avatar
I ended up going with a Generac 2800 PSI gas power washer, along with the Chemical Guys Torq foam cannon. I washed 2 cars with one fill up of the foam cannon (G37 and a Rogue), and had almost enough to complete both cars. I was impressed how the soap/water combination shot out of the cannon and clung to the car. On the G37, after soaping up the car with the cannon, I let it sit for a few minutes, and then got a sponge and moved the soap around, then proceeded to rinse off the car. On the Rogue, I just soaped up the car with the cannon, and then rinsed off. Even without using a sponge to move the soap around, it did a pretty good job of cleaning up the SUV (SUV was moderately dirty), but not quite as good as using a sponge on the car in addition to the foam cannon.
I did hear back from Chemical Guys about using Electric vs. Gas with their cannons, and they commented: "To produce a thick consistency, go gas (2500-3000psi/2-3gpm). The bubbles in the thicker foam act more effectively in the emulsification/encapsulation process."
I'm sure an electric power would still be acceptable, but may be slightly less effective at cleaning the car.
Old 03-17-2017, 12:45 PM
guy from norcal
guy from norcal's Avatar
You definitely want gas. I borrowed my neighbors electric one and it was horrible, with the water hose and the sprayer hose then the electric cord
