Air Compressor
Air Compressor
Can anyone recommend a good quality air compressor that doesn't break the bank?
Perhaps you have one that you're happy with?
I've got little experience with compressors, but looking for something small to handle the light and simple jobs.
Thanks.
Thanks.
I bought this one to do air nailing at my rental house, because I didnt want to haul my 25 gallon upright.
Let's just say I stopped using the big one at my house!!
This little thing works great for nailing, air tools, airing up pool toys!!
1.5 Horsepower, 6 Gallon, 150 PSI Professional Oilless Air Compressor
I have one slightly larger and more powerful Central Pneumatic one from HF that is still cheap and small enough for home but not particularly portable in the G like the one Pat posted. I'm not sure if the little pancake one is much good for an impact gun. I've had it for a couple of years with no complaints at all. Mine is 4 HP, 10 gal tank but it's discontinued. It easily powers any air tool I have (including my air hog impact gun) band is great for general overall light to medium duty use.This would be the closest replacement to the one I have.
Electric Air Compressor - 2-1/2 HP, 10 Gallon, 125 PSI
just go to harbor freight for most of ur cheap tool needs.
one thing about compressors that I learned was that they draw alot of current - no good for use with extension cords. This is true for compressors of similar size as the one black betty mentioned
My only concern with HF is the quality of their products. If you guys use their compressors and they work well, problem solved. While it's not my main intention, would either of those 2 compressors be adequate to handle some impact wrench work? For example, removing rotor bolts.
On the other hand, you will drain the reserve drying a car completely, but thats what my leaf blower is for!!
Seriously my large compressor just sits in the corner!!
Harbor Freight tools are by no means professional grade. By that, I mean, if you are going to use them on a daily basis, they will fail quickly.
As a weekend warrior, they are worth the lower qualit, and cost.
Good to know about your pancake compressor. However some lesser quality impacts (ie Harbor Freight ones) need a higher SCFM to operate with any real power. Better ones are more efficient. I think mine needs like 4.5 or 5 SCFM to operate at peak torque. It'll take lugs off with low air volume but won't break tough suspension or exhaust bolts and nuts.
But for that price sine you have had good luck I'll probably get one just to have a portable option for group DIY days.
And yes, they do use a lot of amperage and can throw your breaker at times. If you need to use an extension cord, it needs to be heavy gauge (12 gauge or better) wire and relatively short (< 25').
I have this one (got it for $99 back in the day) paired up with this impact and both work fairly well. I've done a variety of suspension work with it. It's constantly running, yes, but it's quite the workhorse.
The key to getting the most out of this was replacing the included 1/4" hose with a good 3/8" hose -- it almost like getting a more powerful compressor.
p.s. No trippage on anything, and i do use it with an extension cord at times.
I have the 8 gallon one of this air compressor. I've only had it for a few months but it's good enough for light duty work. I have a 3/8" air ratchet that it has trouble powering it won't do any good for any bolts (even the smaller ones) that are stuck on really well. I ended up going with a little elbow grease and a breaker bar for some of the bigger bolts that my electric impact wrench couldn't take off. FWIW, if you are just a shade tree mechanic, this will get you by, but any medium to heavy duty work and you'll want something better.
And like you said, a good strong breaker bar with some muscle behind it has no substitute.
Just say no!!!!!
This came my way cheap.. Very cheap.
Craftsman - 16640 - 12 Gallon Portable Vertical Air Compressor with Hose and Accessory Kit | Sears Outlet
Main needs include topping off tires, removing wheels, using an airlift suction device for cooling system refill, and other minor home garage tasks.
This is the toolkit I'm considering.
I realize none of these are professional grade, but what about for occasional use?
Airlift tool:
Airlift tool:
do not get a small harbor freight compressor you will regret it big time
