Help How can I get rid of painted pinstripes?
Old 03-23-2012, 02:28 AM
Kuro
Kuro's Avatar
I bought my car used and they were already there so I brought my car to the body shop they told me I have to repaint my car to get rid of them, is it true? Anyway to get rid of them without repaint or wrap my car?
Old 03-23-2012, 08:51 AM
ohsogood
ohsogood's Avatar
Are you sure it was painted? I remember my accord way back when had vinyl pinstripes and I was told a heat gun or a blow dryer would help remove the film.
I'm sure someone else on here can correct me if I'm wrong.
Old 03-23-2012, 09:14 AM
juicybusa
juicybusa's Avatar
I take absolutely no responsibility for this but I've seen oven cleaner used to remove painted stripes/ graphics without ruining the paint
Old 03-23-2012, 09:41 AM
cruzmisl
cruzmisl's Avatar
Most pinstripes are vinyl...If you take your fingernail and go over them you should be able to feel it.
Go to other shops for more opinions.
Old 03-23-2012, 11:54 AM
Kuro
Kuro's Avatar
I'm sure because there was a vinyl one over painted, it sucks
Old 03-27-2012, 06:26 AM
SkylineAWD
SkylineAWD's Avatar
As long as the pinstripes weren't clearcoated over you should be able to remove them. However, depending on the length of time they have been on you might have some sun fade from where the paint was covered to where the paint has not been.
Old 03-28-2012, 12:51 AM
Kuro
Kuro's Avatar
Thank you for everyone's response now I'll check them out that there are over or under clearcoated.
Old 03-28-2012, 01:11 AM
sharkey
sharkey's Avatar
No matter if they were clearcoated you should be able to sand them off by way of wetsanding.
There is still paint under them strips, but you have to be very careful because if there is clearcoat on top.
Because that means there isn't clear on the bottom of it and would require a re-clear.
Pick at it and see if you either chip or pull it off.
Old 03-28-2012, 01:32 AM
Kuro
Kuro's Avatar
Thanks again for info, I'm really appreciated it.
Old 03-29-2012, 06:23 PM
Kuro
Kuro's Avatar
unfortunately they were under clearcoated
Old 03-29-2012, 07:47 PM
SkylineAWD
SkylineAWD's Avatar
If the clear is under it will be a lot easier.
Old 03-29-2012, 09:39 PM
Kuro
Kuro's Avatar
I know, do you think I could still take them off?
Old 03-29-2012, 10:06 PM
cruzmisl
cruzmisl's Avatar
It's painted, I think you'll need to have it sanded and sprayed.
You can try to take it to some different shops and get other opinions.
Old 03-29-2012, 10:26 PM
Kuro
Kuro's Avatar
Thanks I'll let you guys know whats going on.
Old 03-29-2012, 11:29 PM
san~man
san~man's Avatar
The other thing to consider is that, if it's on top the clear, if you take it off the paint around the stripe be lighter than the paint beneath the stripe due to oxidation
Quick Reply: Help How can I get rid of painted pinstripes?
