Buying & Leasing Interested in getting a G37? Ask your Questions in here.
How many miles is too many?
Old 10-28-2016, 09:04 AM
roesler723
roesler723's Avatar
I am looking at purchasing a used G35x/G37x sedan. My budget is not very high so I have been looking at G's with around 100K miles at the minimum. Obviously maintenance plays a huge factor in the condition of any car, but generally speaking what is considered to be TOO HIGH mileage? The 2nd gens (way more appealing than the 1st gen sedans IMO) in my price range seem to be closer to like 120-140k miles. Specifically found an 09 G37xS sedan in white (first color choice) with 140k. Don't see a price on the listing but from a mileage standpoint is it a bad idea?
Old 10-28-2016, 10:06 AM
VenomGT9
VenomGT9's Avatar
Anything over 10 is a risky call
Old 10-28-2016, 11:11 AM
the93owner
the93owner's Avatar
The engines can last a very long time if taken care of well, I've seen many with over 200k. Problem with buying used is you don't always know the maintenance history of the car. If you are looking at a car with 140k, how do you know that the previous owner(s) did their fluids and repairs on time? How do you know they weren't putting 87 octane in the tank? At 140k with poor maintenance the engine is probably already close to done.
I would stick to something under 100k, at that point you can put new fluids in the car and from that point on get at least another 50k out of the engine.
Old 10-28-2016, 12:58 PM
Kb Cool
Kb Cool's Avatar
IDK!! engine close to toast at 140k? I guess it would be possible if they never changed the oil. But, anyways i would be more worried about the alternator, starter, axles, suspension components,ect...... than the motor blowing up.
Old 10-28-2016, 02:17 PM
telcoman
telcoman's Avatar
I had 171796 miles on my previous 06 G35 6 speed manual when I traded it in. Still ran like new.
That was all I used
Still using 87 Octane on my current 2012 G37S at 78k miles.
No problems.
Keep wasting your money
Telcoman
Old 11-09-2016, 02:57 PM
si_driver
si_driver's Avatar
My 2003 G35 is still a daily driver to work etc. (G37 for the weekends only), and it has 256,000 miles on it.
Can't say I babied the car or really did much maintenance on it, I think I only changed the brake fluid twice but the oil was changed every 7,500 with full sync.
And I also only put 87 octane gas in it.
Not sure why people think that putting 87 oct. gas will cause any problems. The knock sensor and the ECU will manage lower oct. gas for you..
Old 11-09-2016, 04:13 PM
kickintheglass
kickintheglass's Avatar
I wouldn't be comfortable buying a car that was driven over 15,000 mi/yr. And that '09 has about 20,000 mi/yr. To me, that's a ton of miles with a lot of unknown occurrences (undocumented collisions, track time, postponed maintenance items), even for a 1-owner vehicle. Of course the rear timing gasket can always take a dump on you, which will negate any savings. This issue affects both high and low mileage cars so it's all up to chance.
My advice is to save up a bit more cash and buy a newer, lower-mileage car. Time is always on your side because inventory is building up from all the trade-ins, causing values to drop every day. What you'll be able to buy today for $15k will be worth $12k in a year.
Old 11-10-2016, 12:36 PM
GeezerB
GeezerB's Avatar
Originally Posted by si_driver
full sync.
Wow. If you didn't want the full performance of your V6, you should of bought a G25. 87 will lower the performance.
