Vendor CZP Lightweight 2pc Rotors for Akebono Sport Brakes - 22lbs!!
I searched all over for a review on this product and haven't found anything.
This thread Sponsor Infiniti Akebono 14" Brake Kits for 07+ G35/G37 Sedan, 08+ G37 Coupe
shows a lot of questions about clearance and pricing, but no reviews.
I am interested in the 2 piece F/R cross drilled/slotted with SS lines and the zinc plating on the rotors. Also the best pads to match these rotors that. I have had a problem in the past with OEM pads that were not bedded properly and I had warped rotors in a few months. That was the dealership that messed up the bedding process and me dropping the ball not doing my own bedding in after I left the dealership.
I just would like to read a few reviews prior to placing an order. Anyone on here care to share?
I found this article which is the same brake kit on the 350Z. It is a track test that Modifed Magizine did of the kit. Hope this helps and gives you the info you where looking for.
https://www.conceptzperformance.com/...edMagazine.pdf
