Is this the larger OEM sway bar
Originally accidentally posted this in the reviews section, But I was wondering if someone could identify if this is the standard S/RWD rear swaybar, as I want to upgrade from my "x"
Rear Sway Bar Swaybar with Links OEM - Infiniti G37 G37x G37S Coupe : ) | eBay
Also, Could anyone give me a concrete answer as to rather or not the Godspeed rear sway will work on my g37x sedan? all OEM bone stock currently, thanks.
I have added both the coupe S (Sport) rear sway bar and just the standard rwd sedan rear sway bar on my AWD sedan.
I would HIGHLY recommend getting just the standard rwd sedan rear sway bar. The Coupe S Sport rear sway bar is too heavy and too thick. It throws off the balance and makes the ride a lot rougher. The neutral feeling, and how the car really should of came from factory, is the standard rwd sedan rear sway bar.
The one in the link does not look like either. It looks like the middle swab of paint is a yellowish color? The sway of paint in the middle for the coupe Sport is blue and the one for the rwd sedan is pinkish/white.
