Any ideas? Bought new home and my lowered G37 can't get down the driveway [PICS]
Old 01-06-2017, 11:51 AM
RMB5190
RMB5190's Avatar
OP I think the answer is rather simple and we are wasting time with these solutions.
Sell your house my friend
Old 01-09-2017, 02:17 PM
Ryne
The Steering Wheel Guy
Ryne's Avatar
For what it's worth, the car is actually pretty low.
Old 01-09-2017, 05:10 PM
sLADe781
sLADe781's Avatar
Originally Posted by micafd3s
... he has a decline at the front.. he needs to raise his rears not just keep it inline with the edge.. raise the rears before the front dips...he needs ramps..
^^This.
I had a similar issue last year with a house I was in the process of purchasing. When I went to view the house, I was in my lowered 3000GT and was able to go up and down the driveway without any issue. After we put in an offer and it got accepted, I went back with my G and scraped so bad I thought my exhaust ripped off!! I tried going up at an angle and using a 2x4 but could not get down the driveway clean. Got a couple of quotes to see how much it would be to redo the driveway and the costs was just too much too soon so I had to pull out.
Hopefully you have better luck and can get it resolved with a ramp or something. Good luck and let us know how everything turns out!
Old 01-11-2017, 01:00 AM
Sarcastik
Sarcastik's Avatar
THIS STORY HAS A HAPPY ENDING!!!!
GETTING INTO THAT GARAGE FELT NEARLY AS GOOD AS WHEN I GOT INTO COLLEGE LMAO!!!
And they Bay Area housing market is a B!T#H right now so even if the car didn't go in I love the house too much to give it up.
So....I definitely got a rash or two on my exhaust system figuring out how to make it in, but I think I'm pretty confident now. I basically parallel park getting the front and rear wheels of one side over "the hump of death" (car is now parallel to the garage door). Then back up as close as possible to the side edge of the driveway. Next I turn the wheels all the way in toward the garage door and get the second set of wheels over the hump of death. So basically a 3 point turn.
Thank you so much to everyone who responded . I love the house and I love the car. As most of do I take a lot pride in my G and I knew it wouldn't be the same if I had to raise it up. I teared up a little when I finally had it inside and saw it comfortable in the warm garage. NO MORE COLD STARTS!
Old 01-11-2017, 01:35 AM
Ryne
Ryne's Avatar
I tear up a little bit when I think of a "cold start" in California.
blnewt (01-11-2017)
Old 01-11-2017, 09:37 AM
Received 4,941 Likes on 4,174 Posts
Lol Ryne^^^^
Awesome that you were able to solve your dilemma, that Y pipe can take quite a bit of abuse and is probably the main point of terror in your scraping. Glad you can go back to enjoying your new house!
Ryne (01-16-2017)
Old 01-11-2017, 09:53 AM
sLADe781
sLADe781's Avatar
Great to hear Sarcastik! Just out of curiosity...how long does the whole process take? To get into the garage and out? lol
Old 01-11-2017, 06:48 PM
RMB5190
RMB5190's Avatar
AWESOME! Glad to hear no modifications were needed as well
Old 01-11-2017, 11:40 PM
Sarcastik
Sarcastik's Avatar
The whole process takes 3-5 minutes I would estimate. I go very slowly and listen closely for any mistakes. To compare, a standard garage entry takes less than 5 seconds. It's actually not usually as easy a 3 point turn sometimes I need to go back and fourth a few times as I make my way over the hump. So like 6 point turn? Anyway I've only done it 3 times and I've gotten more confident each time.
I may get around to creating a video at some point and post to youtube so other people with lowered cars can try the technique .
blnewt, so glad to hear the exhaust pipe is can take abuse. Even though the worst is over I won't be surprised if I have a few more incidents if I'm doing this twice a day, everyday.
Old 01-12-2017, 01:21 AM
Epiphany
Epiphany's Avatar
Definitely. The sounds my car has made in the last few weeks when it was -25 or -30 are disgusting. The groans, high pitch whines and all the clunks to go with it all.
Ryne (01-16-2017)
Old 01-12-2017, 09:21 PM
A video would be a cool addition. As far as how well the Y-pipe holds up, here's mine, and 90% of the damage was done when I was dropped at 25.75", I'm at 26.25 now and rarely any issues. And it still doesn't leak
Old 01-19-2017, 11:25 PM
takeapieandrun
takeapieandrun's Avatar
My current 3" Y pipe scrapes more than my stock Y pipe used to. When I looked under my car I was surprised at how bad the new one got lol, courtesy of my college apartment's speed bumps. I might end up changing back to the stock Y pipe.
Old 01-20-2017, 08:54 AM
I ran a 3" Y also but the rasp that it introduced when mated to my 2.5" TopSpeed flange was too much to bear, so back to stock I went
Old 01-20-2017, 06:10 PM
  #29
takeapieandrun
Yeah, you might have seen my thread in the exhaust section on using a 3" to 2.5" flange adapter to help with the problem.. I think it helped but not sure if I just got used to it instead lmao. I might swap back to the stock Y pipe when i switch back to stock cats for smog inspection to see if it really does sound better like you're saying.
