Will these audi rims/tires fit?
So i was offered this great deal on a set of new rims and tires. They were on a 2011 audi s5. They are 18x8. 5x112 bolt pattern. Offset +35. Size 245 40r 18 michelin pilot alpin pa3 xl.
Will they fit my 2013 g37xs coupe? Or is there a way to make them fit with spacers perhaps?
Thanks in advance
Thanks in advance
They will not fit. We have 5x114.3 bolt patterns. You could try getting adapters to make them fit though.
The adapters will add about 15mm, so you'd be at a net +20 offset, should be a decent, more flush fit, not sure if they make those adapters in a hubcentric that will fit the Infiniti 66.1mm bore. If you get ones that aren't hubcentric there's a higher chance for vibration at higher speeds.
Thanks in advance
Thanks in advance
