Big problems with H&R springs and 20s
Old 03-13-2008, 06:14 PM
kerls08
kerls08's Avatar
Went to check out my car at dealership today.
Went with 20s all the way around wrapped in 255 35 20 bfg tires and it looks great but no one wanted to drive it because of how low it sat.
The rims and tire are same ride height as stock except they are wider and now that it is slammmed they will rub if I hit the smallest bump. On the rear inside wheelwell there is a sharp metal crease where the back quarterpanel meets back bumper.
On the front when you turn the wheel it has about 1/8 inch clearance between frontquarter and top of wheel which would bend the front fender or pop tire if I hit a bump while turning.
The H&R springs says they drop front 1.2 and rear 1.0 it was more like 2.0 and 1.8 drop instead and the car has not been driven so it may settle a 1/8 inch lower still. (I dont understand how that happens)
I cant find anyone who make a mild drop that are out yet.
It is either smaller tires so they are not as wide and tall or find springs that do not drop car so low.
Please anyone that knows about this or has had simillar problem could you help.
kerley
Old 03-13-2008, 06:26 PM
Kidcane
Florida G Club
Kidcane's Avatar
Does not surprise me. Did you take any pics?
Old 03-13-2008, 06:41 PM
kerls08
kerls08's Avatar
The dealership is doing that for me in the morning so I can send info to tirerack where the springs came from.
Old 03-13-2008, 06:44 PM
IP37
IP37's Avatar
mine fit and haven't rubbed yet.. but i went with a 245 falken fk452 tire, the falken tires have more of a curved edge than some others, giving you more clearance..
https://www.myg37.com/forums/picture-share-g-coupe/178643-my-hoopty-on-h-and-r-springs-and-20s.html
and I cut that metal in the back that didn't need to be there, but left the part where it actually bolts together
and actually I think if you look on their site, it says more like average 1.5 front, average 1.4 rear
Old 03-13-2008, 06:50 PM
gan78mao
gan78mao's Avatar
i cut tat piece in the rear too!
wuts ur offset and specs on teh wheels?
Old 03-13-2008, 07:27 PM
kerls08
kerls08's Avatar
They were made by OZ Racing for this car.
They are 20 x 8.5 all the way around.
I am not sure what the offset is but they fit great before I lowered it.
Even box syas 1.2 front 1.0 rear.
I called and talked to tirerack about them before I ordered them and steve looked it up also.
Maybe I got the wrong spring in the box I think they make 2 ride heights
Old 03-13-2008, 07:56 PM
IP37
IP37's Avatar
http://hrsprings.com/scripts/appguid...%20G37%20Coupe
Old 03-13-2008, 08:01 PM
solopresident
solopresident's Avatar
its your offset for sure. 20x8.5. no way it should rub.
i got my front end slammed and i dont rub on 20x9.5
Old 03-13-2008, 08:20 PM
kerls08
kerls08's Avatar
The rims clear I think maybe tires are too wide in the front.
255 35 20 bfgs there tires are more square than oval like stock tires.
Old 03-13-2008, 08:26 PM
solopresident
255/35/20 to
Old 03-13-2008, 08:35 PM
kerls08
kerls08's Avatar
cut rear metal piece stay with those in rear
Go 225 30 20 in front
stock front tires are 27 diameter 8.9 width 4 section height
225 30 20 is 25.3 diameter 8.9 width 2.7 section height
that may help the problem but not much rubber on the front
kerley
that would also leave me with a spare set of rear tires which isnt bad
what do you think
Old 03-13-2008, 09:09 PM
ChOy BoY
ChOy BoY's Avatar
jeez i really cant get these h & r's
Old 03-13-2008, 09:14 PM
MaxToTheG37
Super Moderator w/ Boost
MaxToTheG37's Avatar
8.5" wide and rubbing?
Thats nuts.....
Where did you get your rims?
GiGGaplease
GiGGaplease's Avatar
i would think the only problem is the offset. tanabe springs offers a mild drop.
Old 03-13-2008, 09:15 PM
IP37
IP37's Avatar
pictures would help us help you
Quick Reply: Big problems with H&R springs and 20s
