Feeling at slight shudder at speed (70+)
I have slight shuddering in the steering wheel when I brake. I think it my be embedded material on the rotors. I will replace them with something slotted later but I wanted to know if that would cause a shudder at speed. When driving home today it was the first time I took to 70 (actually I went to 120 but was cruising at 70) and the shudder is slight. I can feel it more than see my steering wheel moving. I also install refinished coupe wheels and new tires. They where high speed balanced so I am not sure if they could be the problem since I never got up to "speed" with the stock 17's.
I think I found the problem. While washing "Brutus" I noticed that my front right wheel has a TON of sticky weights on one side. Either the guy could not balance it correctly, the refinished wheel is wonky or the tire is out of balance somehow. I will take it back to my buddy and see if he can nail it down. I'll be back!
Also the guy who balanced them 1. Did not do a good job at all and 2. Did not index the tires. My buddy rebalanced them the best he could but said the tires need to be indexed. The shudder is way better. Ran down to the Keys this Sunday with the family and doing 75 all the way down it did not bother me at all. Barely felt it. Once I have to replace the tires I will get them indexed correctly.
Oh and the last "Obsession" was named Cesar so I figured why not Brutus for the next one?
After chasing this for a couple of weeks I now know what the issue is. First the Vert wheels where refinished so there was paint/material in the hub area of the wheels. I wire brushed it off and reinstalled. I still had the problem and it turn out to be paint of the Lug seats of the wheels that would not let the lug nuts seat. They would loosen which would cause the shaking.
I figured I would update this thread so if anyone found it thru "Google" they could read the resolution.
Well yes^ and no. I was able to get the paint off the hub area of the wheel but now I'm trying to get it off the Lug Seats. I think after removing the lugs so much after some recent work (1st when I put the wheels on, then to balance them again, then to install the Tein's, then for the front Camber kit, and now for the new rotors and pads) the paint is slowly coming off. I'm going to check the torque again later today.
mmnjtwa
09-07-2015 02:27 PM
