Review Great mild drop solution for your G
Old 04-03-2015, 10:50 AM
11G37S
11G37S's Avatar
So after much searching and input for others on here I found a great mild drop for the G. The option I chose keeps the car specs within factory alignment. The front uses Tanabe NF210 (1") springs only with a .25" strut spacer while the rear is .25" spring mount cutting. Total front is .75" and rear .25".
For the front I installed the NF210 springs and machined a 1/4" strut spacer to mount inbetween the strut and body. This giving the front a total drop of .75" instead of 1". I used a rubber/cork gasket sheet from the local auto parts store. I traced the strut spacer with the gasket material. I kept the stock gasket between the strut pillow mount and the strut spacer then added the rubber gasket between the spacer and body. The Tanabe springs are a softer spring rate compared to stock but driving you can't tell any difference. The 1" drop puts the front at the max of allowed -1 degree of camber from factory "green" specs on alignment. The .75" drop keeps the camber around -.7 degrees and well within the maximum of -1 degree. There is no camber adjustment on the front end so any drop will give negative camber. A huge plus to this drop is there no need for a front camber kit! But also perfect tire to fender gap all the way around the tire, not just the top of the tire to fender like slammed drops.
The rear I used the spring mod below to gain .25" drop. I cut the spring rubber mount with a band saw at 1/4" as precisely as possible. The rubber pushes around and bends a little under pressure during cutting. There is a plastic ring near the inside of the mount to cut through but if done carefully it will come out perfect! I marked each portion of the rubber at 1/4" so I could trace the cutting around the round portion with the band saw. This mild drop gives also a perfect tire to fender gap all the way around. Also the alignment is well within the factory range of adjustments to correct some camber and toe. I recommend anything more than 3/8"-1/2" cut to use a rear camber/toe kit.
https://www.myg37.com/forums/g37-sed...ml#post3817511
The drop installed measured to be 27 3/4" front fenders and 27 1/2" rear fenders. The car drives just like stock and looks like a true "S" model now that it's lowered. If you want a more raked look then leave the stock rear spring perches and only do the 3/4" drop up front. Mine has a very slight rake but only noticeable on flat ground from a far distance to see the whole underbody line. I can produce more strut spacers with sales via PM.
Added alignment specs after drop for reference with no camber kits
The following 6 users liked this post by 11G37S:
blnewt (04-03-2015), Bravo at (04-17-2015), Coltrane1 (03-29-2017), Flakman (04-03-2015), IntricateDetail (04-07-2015), Mkhlmnn (05-24-2016) and 1 others liked this post. (Show less...)
Old 04-03-2015, 04:44 PM
Received 4,941 Likes on 4,174 Posts
Thanks you sir, I'm going to make this a sticky!
Old 04-03-2015, 05:29 PM
Flakman
Flakman's Avatar
Definitely something to think about on dropping mine. Nice. Any pics of what you did on the rears? Also, any idea how this translate to the G37xS sedan? I could probably get mine cut from stainless on the waterjet.
Old 04-06-2015, 07:49 PM
11G37S
11G37S's Avatar
The rears I didn't grab any pics but should have, however I followed the pictures in the link so it was pretty much covered already. It should work just the same for the sedan and X model if they run the same suspension as regular models just taller. I would expect they would also stay in allowed specs for alignment.
Old 04-10-2015, 06:49 PM
11G37S
11G37S's Avatar
Updated first post with top of strut picture to show thread engagement on pillow mount.
Old 04-11-2015, 10:22 AM
socketz67
socketz67's Avatar
The stance is perfect. You should consider packaging this as a kit with step-by-step instructions. Love the ingenuity you put into this mod.
Old 04-14-2015, 04:57 PM
11G37S
11G37S's Avatar
Thanks dude! I could put together some instructions with pictures for those who need it when they want to get some spacers. All I can say is this is the best mod for lowering on perfect fender gap and no extensive costs on camber/toe kits.
Old 04-14-2015, 05:30 PM
Herostar
Herostar's Avatar
How/Where did you get only the front springs, and not a full set?
Old 04-15-2015, 07:02 AM
11G37S
11G37S's Avatar
I got lucky picked up a used front set only when somebody was doing the Eibach fronts and Tanabe rears. You can either get a new set around $200 or wait for a used set to pop up. Maybe even a group buy is possible.
Old 04-17-2015, 12:19 AM
TheLocNar
TheLocNar's Avatar
Nice! Something like this could work on other cars too.
Old 05-09-2015, 06:48 PM
11G37S
11G37S's Avatar
Updated with alignment specs
blnewt (05-10-2015)
Old 02-25-2017, 08:12 PM
11G37S
11G37S's Avatar
Just some recent pics. The front is same wheel to fender gap as rear but the driveway slopes down so this corner has a little more gap when parked.
blnewt (02-26-2017)
Old 02-26-2017, 10:06 AM
Thanks for checking in, been almost 2 years. If you have some time it might help if you could get a distance from the ground to the fender arcs, looks to be in the 26.75" range but pics don't always reflect accurately. And a fresh pic on level ground would be awesome.
BTW, G is looking sharp!
11G37S (03-01-2017)
Old 03-01-2017, 12:12 PM
11G37S
11G37S's Avatar
Thanks! I haven't been on much lately. Got a couple inquiries for spacers. Might try to make a few sets to have for people if they want them. I will get some good fender measurements soon but original measurements were 27.75" Front and 27.5" Rear. I will see if it has settled any over the years.
Old 06-14-2017, 12:05 PM
Mad A
Mad A's Avatar
I'm interested in a set of spacers. I was about to sell my coilvoers because the drop was too much, but if I could get an extra 1/4" I might be happy with them
Quick Reply: Review Great mild drop solution for your G
