bouncy suspension on g37xS
Hello,
I've got a 2009 g37xS (canadian model if it matters) sedan, 105,000km on it.
I've noticed it's a bit bouncy/floaty over rolling pavement. If I could slow the rebound damping it would resolve the issue (to better help describe what is happening)
Is this how the OEM shocks are always, or are they maybe coming up for replacement?
I notice that at very high speeds (200kmph) it is a bit floaty, might be related or it might just be how it is at that type of speeds. Closed course driving, naturally.
From my understanding there are no aftermarket options for the front shocks for the AWD models, is that still accurate?
I would be ok with a 1" or less drop, but wouldn't want anything more than that, if I did go to an aftermarket suspension
thx
thx
I think the shocks are suppose to last longer then 65k miles (i hope o.o) and yes i agree the OE suspension is a bit too bouncy. I think think the only way to improve on that is to either get a nice quality coilover system with independent rebound and compression or get custom shocks. Ride quality/bounciness is mostly subjective but there are alot of variables that influence it such as type of dampening in the strut (hydraulic,gas, size of shock portion), spring rates, body mounts, fittings, vehicle weight and chassis. Most cars will feel floaty at 200kmph... and the G is no exception. I've rode in my uncles s63 many times and going 100mph in that feel like only about 60-70 (now i understand why he gets so many speeding tickets..you don't realize your actually going that fast!). But then again were comparing a 35-40k car to a 140k car and the s63 also weighs almost 5000Lbs compare to the G's 3800 Lb.
The only aftermarket replacement shocks for the AWD G's are the KYB's. You can always go with a custom build and have a reputable suspension company customize Shocks to fit the front of the AWD g's. Anything if possible is your willing the pay the price lols =p.
Are the available KYB's a "cheaper oem replacement" or are they actually a "performanceish" shock?
Has anyone had custom shocks put together? I know I've had custom Koni yellows built before (I used to scca touring cars) at prices that were surprisingly cheap. I might reach out to my old contacts there.
I should also state that I'm not opposed to a stiffer ride, should I be able to find something "sportier" for the fronts
If you can get Koni to build shocks for the awd g you will be a hero. Lots of folks here would love them nut Koni has continuously said they have no plans of building them. Kind of dumb if you ask me as there would be a lot of demand.
And just to be clear, I would be getting them made custom by Koni's amateur racing division, likely over $500/corner plus core. it would not result in an off-the-shelf strut for $89.99 :P
It's a pretty niche application, and I'd bet that most G37x drivers aren't looking for Koni caliber struts. I fully understand why they're not making yellows for our application.
[our application.
[/QUOTE]
I'm not sure I fully agree - if you look at their catalog, they make their Sport shocks available on a number of platforms that I would say are more niche than the G37x. You have to remember that this model isn't just a big seller in Canada but also in a large part of the Northern US all you can find are AWD G37s.
[/QUOTE]
I don't want to hijack this thread...however I find the ride a bit to bouncy around corners. My Maxima with the wide tires and Eibach drop can corner better than this G37xS! I would prefer to go with springs as coilovers are a harsher/stiffer ride and I don't want Eibachs or Tein cause the drop is too dramatic...I don't want to drop more than 1 - 1.5" front and 1"back. Has anyone else found a set of springs for the G37xS coupe? (2012)...
Chris, How is that possible? Where do you live and where are you getting these springs....or you car is a 4 door. I called Swift yesterday and they said that they do not mfg springs for the x coupe...
my bad, I assumed springs were the same for sedan and coupe. I have a sedan.
