Anyone have any experience with rotors/pads from Brakeperformance.com?
#31
MACS, did you think about going with slotted or did the brake performance guys steer you away from them?
#32
Man those look pretty nice! Out of curiosity, why did you decide to go with slotted as opposed to only cross-drilled? I think I've heard that slotted are supposed to be better with brake dust, but I wondered what went into your decision.
The guys over there had good results w/ the Stoptech pads & these rotors so I was pretty certain they'd work well on our Gs. Didn't see any that were just drilled so I can't compare, I'm sure they'll look great on MACs G.
I've been pretty happy w/ my OEM brakes so if these perform as well and the zinc holds up over time I'll be completely satisfied w/ the purchase.
Especially since these rotors are so affordable
#33
I actually considered the dimpled/slotted and even ordered them. When I called to ask some questions, the CS rep actually changed my mind and saved me some $ in the process. The whole deal, rotors and pads was right about $523. If you know how to change your own brakes, that's your total. If not, add labor to put them on which should only take an hour or so.
#34
#35
MACS, what Brake fluid are you going with? I'm wondering if just the generic DOT3 is adequate for a daily driver w/ aggressive driving now & then, or should I look into Motul or something? Oh, and BTW do you know how much fluid I'd need for a whole flush & fill (again for the baby non-S brakes, lol).
Are you also going to grease the pad, caliper contact area?
Sorry for all the noob brake questions but it's been about 20 years since I did a DIY brake job
Thanks!
Thanks!
#36
blnewt, I have never done a brake job. I really want someone to teach me because I keep hearing how easy it is. I'm a hands on learner, so I am not cool watching a video and then doing my brakes. As we know, they are a pretty damn important part of the car!
I got the ATE super blue racing fluid. The whole system was flushed using less than 1 whole can. I'd say about 2/3 to 3/4 of it was used. To be completely honest, I didn't really notice a difference (not tracking or racing, though). I think if you're not tracking or racing, the regular DOT 3 will be fine.
#41
Okay, I've got these on the car. Brake performance rotors and stop tech street performance pads.
I need to bed them in because right now they make a horrible moaning sound when I am almost at a stop. The tech said the stop tech pads have a very hard compound.
My first impression is that the car stops better. The pads have a much better bite, it seems, than the stock ceramic pads. I'll let you know if bedding helps that moan go away and provide some pictures.
#43
Here's the pics of front and rear:
#44
Okay, update time: I bedded the pads in, as described on stoptech's website. 60mph-10mph with hard braking. I did it 8 times, let 'em cool, and did it again. The moan is gone and she stops quite well. I won't say way better than before, but better.
#45
Thanks for the update, they look pretty bad-as$ in there
Making it even harder to have to wait for my install
BTW, did your installer use that caliper grease between the caliper and pad? Just wondering if I'll need that?
And did you compare your OEM rotor weight to the new rotors, from all I've read they seem to be the same.
