Project Completed: Folding Side View Mirrors
#91
Resurrecting this thread.
I completed the install on my sedan and am looking for information on hooking up the power fold module.
ModMe - I sent you a PM asking about the wires you tapped to get the power fold to function properly. Any help on this?
Did anyone else successfully install this module and has it working properly? I have the module and associated wiring, just need to figure out how to hook the damn thing up. Tried testing different voltages within each wires during certain function but that did not work as I had expected.
#92
my mirrors don't auto fold...ahhh
So bringing back and old thread again..my mirrors aren't folding after a body shop messed with door panel.. I thinking a fuse blew..cant locate fuse..can someone help me with the fuse location?modme? Thanks
#93
On my setup, I tapped into the power window switch to get power to the folding mirror circuit.
If possible, I would double check the wiring harness in the door to make sure everything is tight and secure. There a couple of fuses you could check as well. I'm sure it is something simple.
Good luck!
Good luck!
#94
..." The mirror covers are also perfect swap with the coupe's."
So does that mean the covers are removable, and you can use the covers from your coupe's "manual folders" if need be?
I can probably find the infiniti OEM parts at a reasonable price. Its getting things painted to match, etc., that would jack up labor costs if I wanted to do this.
#95
The mirror covers are the same for both the coupe and the convertible. I reused my covers when I swapped to the convertible mirror assemblies.
OEM part numbers:
Left side: K6374-JL00A
Right side: K6373-JL00A
Both are about $52 each on amazon as of today but you might find them cheaper elsewhere.
If I recall, they come primed but not painted. You would have to get them painted on your own.
OEM part numbers:
#96
Just a heads up if anyone is trying to install the auto fold module with this mod I have a DIY.
https://www.myg37.com/forums/d-i-y-i...e-install.html
Victory
17
10-27-2022 03:45 PM
