Audio Bit One's compatibility with Bose?
Hey guys, I've done some reading about the Bit One, and wondering if I can just install the sound processor in my '11 G37 coupe with the Bose system without needing to change out amps as well? I thought I read some (maybe just one) thread(s) with folks incorporating a sound processor and retaining the Bose amps and speakers? All I can seem to find today are threads with guys changing out entire systems; I may do so in the future, but, as of now, I'm only looking to improve the quality of the signal and sound of the Bose and add a single sub and amp.
If this is possible, how do I go about wiring it? I know the signal from the head unit is flat, so can I just catch the high output signal from the wires before the Bose and then take the rca outputs and connect the wires back to the Bose amp, or would the Bose amp just do some weird eq'ing and mess up the cleaned up signal from the Bit One?
I have multiple two-channel amps, a nice component set, and quality 6x9s from a previous vehicle, but I wasn't looking to gut my entire car just yet. I just picked it up 45 days ago, and want to spend more time and money on exhaust, tune, and wheels before I completely do the system (I already installed Swift springs and have the Takeda CAI.)
I've installed many complete audio/video systems, built custom boxes and speaker adapters, and can understand wiring diagrams fairly well, but hadn't used a SP on a stock system yet, so not sure if I can despite believing I read I could for my previous car -- Volvo S60R. Any help would be appreciated, guys.
Going to install the amps in the spare tire well on a rack lined with mirror plexiglass or cover it with some 3M vinyl. Then I'm going to build a false floor, to cover the amps, with some half inch plexiglass that has the JL logo cut out and some fiber board.
So much for waiting... I already did some test fitting and took measurements today.
mmnjtwa, I actually just signed up to look into this. I am in the same boat as you and wanted to upgrade the quality of the signal and bypass the Bose amp all together. I was looking at an Audison AP8.9 Bit as the signal processor and amp.
I have an amp and Sub from my previous car that I will be using.
then later on I would redo the component speakers
Seems, to me, that you can bypass the Bose amp and use an external DSP and amp to clean up the signal and run the factory speakers. Just beware of the lower impedance of the Bose speakers. I'm going to pick up a Bit One and some Hertz components tomorrow. I'll gradually install everything in my spare time over the next week or so.
misc
29
05-24-2023 03:57 PM
Murkr
09-23-2015 04:52 PM
