Need help choosing custom trunk solution, Maximum bass
Old 12-16-2014, 09:23 PM
  #46
Neddy_G37
Neddy_G37's Avatar
hey, its been a while, how are things holding up?
Old 04-05-2019, 02:20 AM
  #47
oNeNoNly
oNeNoNly's Avatar
Question to you.
I was reading the information about box types and what the difference between them are. I am prepared to build a box into the trunk of my car. I'd like to make a 4th order. I have 2 12 inch Skar vxf. I'm wondering if you may be able to help me out with a ratio you think I should go with. I want to have a wide range of frequencies and just don't know how to decide on size of Sealed vs. Ported area. My max width is 38 inches. I have a 6 inch diameter aeroport that can be from 10 inches long to 21 inches long. Just have to add or subtract pieces. It's the 6 inch versa tuned port from Big *** ports. It came with a midmount accessory so i can have 7 inches of external port and 14 inches internal and can be pushed in or out depending upon what I desire. So, can you possibly help me? You seem to have the knowledge that I lack and I cannot afford $50 for someone else to make a design for me... Thank you in advance. Fingers crossed that you still have an account with G37
Originally Posted by Neddy_G37
This is a great example of a 4th order bandpass that utilizes one sub, takes a ton of power to operate efficiently, but can be made to work in a tight space with a small sub sounding much larger!
Falker11
01-11-2016 02:22 PM
flyingnimbus
10-03-2015 12:12 AM
Lances Infiniti
09-28-2015 02:39 PM
flyng_fool
09-17-2015 08:58 AM
Quick Reply: Need help choosing custom trunk solution, Maximum bass
