USB to bluetooth audio adapter
#48
Hello everyone. A bit late to the party, but I too, just like the rest of you, am frustrated with the lack of playing audio from my phone. I read all the posts in here, and after looking at different bluetooth USB dongles, I decided to go with this based on reviews:
I got it from eBay (http://www.ebay.com/itm/Mpow-3-5mm-Streambot-Slider-USB-Bluetooth-Audio-Streaming-Music-Receiver-Adapter-/151699991392?pt=LH_DefaultDomain_0&hash=item2352062b60) free shipping. Really hoping it works with no lag or stutter. I will let you know when I receive it and try it out.
Amazon.com: MPOW Streambot Slider Bluetooth Audio Music Streaming Receiver Adapter - Retail Packaging - Black: Cell Phones & Accessories
#49
I got it from eBay (Mpow 3 5mm Streambot Slider USB Bluetooth Audio Streaming Music Receiver Adapter | eBay) free shipping. Really hoping it works with no lag or stutter. I will let you know when I receive it and try it out.
#50
Anyone tried a Bluetooth to 30pin dock adapter?? NAXA makes one, for instance.
I will hopefully soon be the owner of a 2012 G37x, without Nav.
Other than the NAXA - NAB4003, I wonder if anyone has tried the NAB4000? It is a blutooth adapter meant to be used with stereos that have a 30-pin dock. Judging by the website, it might have superior blutooth to the NAB4000. My thinking is to just take a USB to 30 pin and plug it into the USB. I think there is a good chance it works.
In fact, I wish someone would have already tried this or another 30-pin bluetooth adapter. There are several. My thinking is that these are intended to emulate an iPhone and allow a person to use an-otherwise obsolete 30-pin dock stereo with any bluetooth capable device. That is, essentially, what we want to do. It's worth a shot, unless someone can comment on some sort of loss that happens going from 30-pin to USB, which could be the case.
MStrike (11-17-2021)
#51
Any luck with this? I'm still hoping that someone finally finds a product that works....
#52
#53
I have an 08, this is what I use. Amazon.com: HomeSpot NFC-Enabled Bluetooth Audio Receiver for Sound System: Electronics
Thanks for the tip and any updates you can provide.
#54
I've been using the NAXA-NAB. While it is cheap, convenient, and simple, it is not an adequate sollution. It does weird things. It "skips" or deletes tiny fragments of audio, and sometimes it sounds like it is playing too fast. The 10-second or so lag is not a big deal to me, but it is there. Really, if it just played that audio without the frequent skips or weird distortions, it would be great.
FWIW, it is taking the streaming audio and then dumping it into an .MP3 file. Your car tries to play the MP3 file, and it almost works. I get the impression it COULD work, but it is just a super-cheap device. I would happily pay $30 for one if it worked.
SO - OTHER POSSIBILITIES - the GROM set up that takes-over your XM-SAT input works, and I bet it works well. But it is pricey. And you lose XM radio. I dislike that.
The only other viable option I see is a wired FM-Modulator. Here is one that just provides a Line-in:
A similar model includes bluetooth:
These patch into your antenna and then occupy an FM station. When your radio is tuned to the FM station, you hear whatever is going through the device (bluetooth, or line-in). You do have to buy two small pig-tail adapters, because your G37 doesn't have the same style of FM antenna connections. Browsing online, it likely ads $15 to a set up.
I think this probably provides the best inexpensive experience for people wanting to add BlueTooth audio to non-nav G37.
I might do it. . .
Amazon.com : iSimple IS31 Antenna Bypass FM Modulator for Factory or Aftermarket Car Radios : Vehicle Audio Auxiliary Adapters : Car Electronics
Amazon.com: iSimple ISFM21 TranzIt Universal Bluetooth Enabled FM Transmitter Car Kit for Android Devices, Blue: Car Electronics
I might do it. . .
Last edited by Brad Madsen; 10-19-2015 at 05:16 PM. Reason: Added info re adapter for antenna connections
#56
has no one tried those little USB-powered Bluetooth adapters? (need a USB cig lighter adapter to power it)
it works great in my '08 Evo, which has Bluetooth for phone, but doesnt do audio. plugs into RCA inputs with a 3.5mm to RCA cable.
#57
G37 after a certain year do not have RCA inputs or Bluetooth Audio.
But THAT is the REAL problem. Non-Navi G37 after a certain year (2008?) don't have ANY audio input other than the USB port. NO RCA INPUT. NO 3.5MM input. NO BLUETOOTH AUDIO. Hence, the various work-around and what not.
#58
I've read several threads addressing the lack of bluetooth audio in non-navi G37. And, like Landshark, somebody eventually chimes in and points out that there are many, many, cheap Blue-tooth audio adapters that just plug into either an RCA or 3.5mm headphone jack.
i thought that was later, like 2010+ had no RCA's.
there's this:
Nissan Infiniti 02-11 Auxiliary Input Adapter Kit - SAT Emulation
can't confirm or deny it works, though.
these cars are a rat's nest of confusion as far as coupe/sedan/convertible/nav/no nav/6mt/auto/AWD/RWD/etc.
#59
The GROM adapter works, its been confirmed. Once you add it all up, I want to say the cost would be around $200, though.
I do wish somebody would clearly explain whether or not the Tune2Air (or Air2Tune?) adapter works. Best I could tell, it might work if you got it enough power? Like the USB input doesn't put out enough for it to work, but if you added some juice, it might?
#60
Brad Madsen (10-26-2015)
