Finally some inspiration for that next mod
#46
http://g37.pl/bt/
In your case you would just connect them to a 3.5mm plug or some RCA jacks, instead of a bluetooth receiver.
#47
Yes sir, Charlotte--we got to hang out or something. As far as my aux input,..I got lucky and my G has the rca's in the mid console...so i just used an rca to 3.5mm headphone jack. Thats it, I select aux on the radio and its done. Sounds awesome too, no need to increase volume or anything more than the radio.
The screen is perfect, nothing is cutoff. Side to side there is a few millimeters of black space (not noticeable), its the edge of the face of the nexus. Top to bottom is exact fit, so when needing to drop down the status bar its a tight fit for your finger tip..
I don't mean to go off subject but I live in Hickory. I'm down in Charlotte every few weeks. Was just down there last Friday at CIN Motorsports to have HFC's installed actually. Anyway, would love to see this up close before I consider doing anything similar. Any other DIY mods you've done?
Paratrooper (04-15-2014)
#50
PM me the next time your coming down.
#51
Paratrooper, I assume you decided not to go with the dual screen. Where did you find that dual set up? I've been talking to sound shops in the area and it almost seems like you have to map out what you want for them to "see" if they can do it. This is nuts. The exterior and engine mods are plentyful but the electronic mods seems to be rocket science.
#52
I have not found a need for the factory screen, would still be sick to have it somewhere..
Car audio, mobile video, vehicle security, remote starters, and mobile electronics*-*Jersey City NJ*-*201 Motoring *-*(201) 793-8813
TazRider (04-16-2014)
#53
I was thinking, where did you put your usb hub? Did you leave it in the console or bring it to the glove box? I was thinking of running an extension usb female and replacing that useless iphone port with the line to the hub. Keeps it looking 100% stock and everything hidden.
#55
#57
I'm combining Paratroopers setup with:
https://www.myg37.com/forums/audio-v...nexus-7-a.html
That way I can use dashcam to display the stock screen/ settings etc. I still want that to be able to connect a new phone to bluetooth etc
All the parts are ordered. I'm using USBRom. Should all be here by next weekend.
Edit should mention using a different UVC capture device, that Febon is too expensive!
#58
